Rack Compatibility
Check that your rack is compatible with the slide rail and
cable management assembly options. The optional slide rails are
compatible with a wide range of equipment racks that meet the following
standards.
Structure
Four-post rack (mounting at both front and rear). Supported rack
types: square hole (9.5 mm) and round hole (M6 or 1/4-20 threaded
only.
Two-post racks are not compatible.
Rack horizontal opening and unit vertical pitch
Conforms to ANSI/EIA 310-D-1992 or IEC 60927 standards.
Distance between front and rear mounting planes
Minimum 61 cm and maximum 91.5 cm (24 inches to 36 inches).
Clearance depth in front of front mounting plane
Distance to front cabinet door is at least 2.54 cm (1
inch).
Clearance depth behind front mounting plane
Distance to rear cabinet door is at least 90 cm (35.43 inches)
with the cable management arm, or 80 cm (31.5 inches) without the
cable management arm.
Clearance width between front and rear mounting planes
Distance between structural supports and cable troughs is at least
45.6 cm (18 inches).
Minimum clearance for service access
Clearance, front of server: 123.2 cm (48.5 inches)
Clearance, rear of server: 91.4 cm (36 inches)
