Server Overview
This topic provides a high-level introduction to the main
components and capabilities of the server.
Chassis
Rack-mountable server.
CPU
One or two processors are supported: 8-core, 4.267GHz, 130W each,
installed on the motherboard assembly.
Memory
16 DDR4 DIMM slots are supported:
I/O expansion
Three low profiles x8 PCIe Gen3 slots. All slots support x8 PCIe
cards, two slots support x16 PCIe cards mechanically.
Storage devices
For internal storage, the server provides:
Eight 2.5-inch drive bays accessible through the front
panel, support SFF SAS/SATA drives with 4 slots NVMe
enabled.
Internal SAS HBA card.
Support for non-RAID LSISAS3008 HBA.
USB ports
Two external USB 2.0 ports (front panel).
Ethernet ports
Four 10GbE 100/1000/10000 Mbps, RJ-45-based ports on the rear
panel.
Power supplies
Two hot-swappable A266 1.2kW (N+1).
Cooling fans
Four hot-swappable, redundant fans at chassis front
(top-loading).
SP
Oracle Integrated Lights Out Manager (Oracle ILOM) on
motherboard.
