Rear Panel
Components (Installation)
Note - You must follow the proper sequence when connecting
cables to the server. Do not connect the power cords until all data
cables have been connected.
1
Power supply 0 Fault LED
8
NET 0 100/1000/10000 port
2
Power supply 0 OK LED
9
NET 1 100/1000/10000 port
3
Power supply 1 Fault LED
10
NET 2 100/1000/10000 port
4
Power supply 1 OK LED
11
NET 3 100/1000/10000 port
5
PCIe card slot 1
12
NET MGT port
6
PCIe card slot 2
13
SER MGT/RJ-45 serial port
7
PCIe card slot 3
