Applications Administration Guide > Configuring the Inbox > Configuring Action Buttons for Inbox Views (in Siebel Tools)In the preconfigured Siebel application, users take action on an Inbox item by choosing from the Action drop-down list. You can configure the Inbox so that the first five values in the Action drop-down list display as buttons on the UInbox Item Task List Applet applet. See Figure 11 for an example. Activating the Inbox Action ButtonsWhich controls you activate depends on whether your application runs in standard or in high interactivity mode. For more information about working with controls in applets, see the section about editing applet layout in Configuring Siebel Business Applications. To configure action buttons for standard interactivity
To configure action buttons for high interactivity
Configuring Background Colors for the Inbox Action ButtonsIf you edited the cascading style sheet for the list applet and changed the background colors, you need to edit the background colors for the action buttons so that they match the applet. |
| Applications Administration Guide |
