Siebel Assignment Manager Administration Guide > Basic Assignment Manager Configuration > Process of Creating Assignment Criteria for Use in Assignment Rules >
Creating Assignment Criteria Attributes for Assignment Criteria
An assignment criterion includes one or more assignment criteria attributes, stored as child assignment criteria attribute object definitions. Assignment criteria attributes are implemented as object definitions of the assignment criteria attribute object type. Assignment Criteria Attribute is a child object type of Assignment Criteria as shown in Figure 3. The set of assignment criteria attributes in an assignment criterion determines the set of list columns that appear in the Values list. One list column appears in the Values list for each assignment criteria attribute in the assignment criteria. In Siebel Tools, as Figure 7 shows, the Account Wildcard assignment criteria (the Account Name assignment criteria with a display name of Account Wildcard) has an Account Name and a Site Name list column in the display of its child Value records. Both the Account Name and Site Name list columns correspond to the Account Name assignment criteria attribute.
Figure 7. Assignment Criterion with Child Assignment Criteria Attributes
If there were more assignment criteria attributes for this assignment criterion, each would have a list column in the Values list. The Score list column is automatically provided, and the Expertise Code list column appears in this instance because the assignment criteria has a Use Expertise property setting of TRUE. Composite Criteria
Assignment criteria attributes make it possible for a single assignment criterion to consist of multiple attributes, known as composite criteria. For composite criteria, all the attributes must have a 1:1 relationship and should refer to the same base table record. For example, the Account City-State-Country is a good composite criterion because San Mateo (city) resides in the state of California (state) and California resides in the USA (country). All of these attributes are stored on the same record in the same table. NOTE: It is not possible to create composite criteria with attributes based on different tables.
This task is one step in Process of Creating Assignment Criteria for Use in Assignment Rules. To create an assignment criteria attribute
- Start Siebel Tools.
- In the Object Explorer, expand the Assignment Criteria object, and select the Assignment Criteria Attribute object.
- In the Assignment Criteria window, select the assignment criteria for which you want to enumerate assignment attributes.
- Lock the project for the object by choosing Tools > Lock Project (or Alt+L).
The pencil icon appears in the W field to indicate the project for the object is locked.
- Select the Assignment Criteria Attributes window, then choose Edit > New Record.
- Configure the assignment criteria attribute by setting values in the appropriate fields.
- In the Name field, type the name of the new assignment criteria attribute.
- In the Assignment Attribute field, select the assignment attribute for this assignment criteria.
- In the Display Name field, type the name for the assignment criteria attribute.
- In the Store Column field, specify the column in the assignment factor items table where the value for the assignment criteria attribute is stored.
- In the Display Sequence field, specify the sequence in which the assignment criteria attribute appears.
- (Optional) In the Pick Applet field, choose a pick applet for the assignment criteria attribute to allow users to view or select values for the assignment criteria attribute.
NOTE: For composite criteria, repeat Step 5 and Step 6 as many times as is necessary.
For more information on these properties, see Table 12.
You also need to update the siebel.srf file and run various server administration tasks using the procedures in Updating Your Assignment Manager Deployment with New Configurations. Table 12 shows some of the properties of the assignment criteria attribute object type.
Table 12. Assignment Criteria Attribute Properties
Assignment Attribute |
Name of the assignment attribute that this assignment criteria attribute is based on. Selected from a drop-down list. |
Display Name |
List column label that appears for this assignment criteria attribute in the Values list. If omitted, the Name is used in the list column label. |
Display Sequence |
Order in which the list column for this assignment criteria attribute appears in the list applet, relative to those of other assignment criteria attributes in the assignment item. A lower number places the list column further to the left. |
Name |
Name of the assignment criteria attribute, for identification. This name must be unique within the parent assignment criteria. |
Pick Applet |
If a picklist is defined for the associated assignment attribute, you specify the name of a pick applet to display the picklist for selection of a value in the attribute's list column. |
Store Column |
Specifies the column in the assignment factor items table (S_ASGN_RULE_ITEM) in which to store the value for the assignment criteria attribute. There are four columns of each data type (Number, UtcDateTime, and Varchar) provided for storage of assignment criteria attribute values in each assignment criteria. You must specify a unique value, between 1 and 4 inclusive, for each assignment criteria attribute of the same data type. The data type can be determined from the Data Type property in the referenced assignment attribute object definition. NOTE: You can have up to four assignment criteria attributes for each assignment criterion (a composite criterion can have a maximum of four attributes).
