Table 6. Software Installed in the Development Environment
Where to Find Installation Instructions |
Database software. For example, IBM DB2 Universal Database, Oracle, or SQL Server. |
Third-party relational database software. |
DEV_DB_server |
Product documentation for the database application. |
Siebel database schema |
Installing and running a database script creates a database schema and populates some of the tables with seed data. |
DEV_DB_server |
Siebel Installation Guide: Servers, Mobile Web Clients, and Tools for Microsoft Windows |
Siebel File System |
A shared directory tree used for storing files not managed by the database software. |
DEV_server |
Siebel Gateway Server |
Software that handles connections between Siebel clients and servers. |
DEV_server |
Siebel Server |
Application server software. |
DEV_server |
Siebel Dedicated Web Client |
A client in which application layers except the user interface reside on the server. |
DEV_server |
Web server such as Microsoft Internet Information Server (IIS) or IBM HTTP Server. |
Web server required for the Siebel Web architecture. |
DEV_server |
Product documentation for the Web server. |
Siebel Tools |
The primary software for configuring Siebel client applications. |
DEV_tools_A DEV_tools_B |
Using Siebel Tools |
Siebel Mobile Web Client |
A client in which application layers reside on the user's personal computer. |
Sample Database |
The sample database that you can use to test, evaluate, and configure. |
Siebel Installation Guide: Servers, Mobile Web Clients, and Tools for Microsoft Windows and the release notes documentation for your Siebel application. |
Microsoft Internet Explorer |
The Web browser used to display the interface for the Siebel Web Client and the Mobile Web Client. |
DEV_client_A DEV_tools_B |
If this software is not pre-installed on the client computer, go to the Microsoft Web site for installation instructions. |
