Developing and Deploying Siebel eBusiness Applications > Installing Siebel Applications >
The Test Environment
Table 7 lists which products to install in the test environment, on which machine NREC installed each product, and where you can find installation instructions. For detailed information on supported software, read System Requirements and Supported Platforms on Siebel SupportWeb. NOTE: The NREC example assumes a Windows environment.
Table 7. Software Installed in the Test Environment
Product Installed by NREC |
Where to Find Installation Instructions |
Database software. For example IBM DB2 Universal Database, Oracle, or SQL Server. |
TEST_DB_server |
Product documentation for the database platform. |
Siebel database schema |
TEST_DB_server |
Siebel Installation Guide: Servers, Mobile Web Clients, and Tools for Microsoft Windows |
Siebel File System |
TEST_server |
Siebel Gateway Server |
TEST_server |
Siebel Server |
TEST_server |
Siebel Mobile Web Client |
TEST_client_A (and other client machines from which to test access) |
Web server such as Microsoft Internet Information Server (IIS) or IBM HTTP Server. |
TEST_server |
Product documentation for the Web server. |
Microsoft Internet Explorer |
TEST_client_B (and other client machines from which to test access) |
If this software is not preinstalled on the client computer, go to the Microsoft Web site for installation instructions. |
