Table 50. Predefined EAI Business Services
EAI XSD Wizard |
CSSXMLSchemaWizard |
Used to create integration objects based on XSD files. |
EAI XML XSD Generator |
CSSEAISchXSDService |
Used to generate an XSD file from an integration object. |
EAI Transaction Service |
CSSBeginEndTransactionService |
EAI Transaction service for working with Siebel transactions, such as begin and end, to find out whether in transaction. |
EAI MSMQ Transport |
CSSMsmqTransService |
EAI MSMQ Transport. |
EAI MQSeries Server Transport |
CSSMqSrvTransService |
EAI MQSeries Server Transport. |
EAI HTTP Transport |
CSSHTTPTransService |
EAI HTTP Outbound Transport. For information, see Transports and Interfaces: Siebel Enterprise Application Integration. |
EAI Siebel Adapter |
CSSEAISiebelAdapterService |
EAI Siebel Adapter. For information, see EAI Siebel Adapter. |
EAI Query Spec Service |
CSSEAIQuerySpecService |
Used internally by the EAI Siebel Adapter to convert the SearchSpec method argument as a string to an Integration Object Instance that the EAI Siebel Adapter can use as a Query By Example object. |
EAI Import Export |
CSSEAIImportExportService |
EAI Import Export Service (import and export integration object from or to XML). |
EAI BTS COM Transport |
CSSEAIBtsComService |
EAI Siebel to BTS COM Transport. |
EAI DLL Transport |
CSSDllTransService |
EAI DLL Transport. For information, see Transports and Interfaces: Siebel Enterprise Application Integration. |
EAI Data Transformation Engine |
CSSDataTransformationEngine |
EAI Data Transformation Engine. For information, see Business Processes and Rules: Siebel Enterprise Application Integration. The display name for this business service is EAI Data Mapping Engine. |
EAI Null Envelope Service |
CSSEAINullEnvelopeService |
EAI Null Envelope Service. For information, see XML Reference: Siebel Enterprise Application Integration. |
Siebel Message Envelope |
CSSEAISMEnvelopeService |
EAI Siebel Message Envelope Service. For information, see XML Reference: Siebel Enterprise Application Integration. |
EAI Dispatch Service |
CSSEAIDispatchService |
Dispatch Service. For information, see Business Processes and Rules: Siebel Enterprise Application Integration. |
EAI Integration Object to XML Hierarchy Converter |
CSSEAIIntObjHierCnvService |
EAI Integration Object Hierarchy (also known as SiebelMessage) to XML hierarchy converter service. For information, see XML Reference: Siebel Enterprise Application Integration. |
EAI MIME Hierarchy Converter |
CSSEAIMimePropSetService |
EAI MIME Hierarchy Conversion Service. For information, see Siebel EAI and File Attachments. |
EAI MIME Doc Converter |
CSSEAIMimeService |
MIME Document Conversion Service. For information, see Siebel EAI and File Attachments. |
EAI XML Converter |
CSSEAIXMLCnvService |
Converts between XML and EAI Messages. For information, see XML Reference: Siebel Enterprise Application Integration. |
EAI XML Write to File |
CSSEAIXMLPrtService |
Print a property set to a file as XML. For information, see XML Reference: Siebel Enterprise Application Integration. |
EAI XML Read from File |
Read an XML file and parse to a property set. For information, see XML Reference: Siebel Enterprise Application Integration. |
XML Converter |
CSSXMLCnvService |
Converts between XML documents and arbitrary Property Sets. For information, see XML Reference: Siebel Enterprise Application Integration. |
CSSXMLCnvService |
Converts between XML documents and XML Property Set or Arbitrary Property Set. For information, see XML Reference: Siebel Enterprise Application Integration. |
