Siebel Field Service Guide > Business Service Methods Reference for Field Service > Charges > CreateTimeCharge MethodCreateTimeCharge is used to create charges based on reported time. UsageThis method is called directly from the FS Charge List Applet - Auto Charge (used in the Activities screen > Activity List > Charges view). This view is used to create charges for an activity. The business service is called directly from the applet class. This method then creates the time charges for the activity, based on the hourly rate of the activity owner. Additional DetailsThis method is not used as part of any workflow process. If you do not wish to have expense adjustment charged, remove the user property ChargeBusinessServiceMethod1 on the Time Sheet Daily Hours Item business component. See Table 137 for more information. |
| Siebel Field Service Guide |
