Siebel Field Service Guide > Business Service Methods Reference for Field Service > Charges > CreateTimeEntitlementCharge MethodCreateTimeEntitlementCharge is used to create time entitlement adjustments. UsageThis method is called directly from the FS Charge List Applet - Auto Charge (used in the Activities screen > Activity List > Charges view). This view is used to create charges for an activity. The business service is called directly from the applet class. This method then adjusts the cost of the hourly resource, based on the entitlement associated with the activity. Additional DetailsThis method is not used as part of any workflow process. If you do not wish to have time adjustment charged, you should remove the user property ChargeBusinessServiceMethod2 on the Time Sheet Daily Hours Item business component. See Table 137 for more information. |
| Siebel Field Service Guide |
