Siebel Field Service Guide > Setting Up and Using Scheduling > Reloading the ABS and Optimizer CachesThis task is a step in Process of Setting Up Scheduling. Dispatchers and field service engineers may change the following specifications for service activities:
NOTE: Planned End, Planned Completion, and End are all the same. All these terms appear in the user interface. All changes require updating an in-memory cache of the activities. If a user changes an activity in the database, it becomes out of sync with the cache in memory. You can reload activity data manually into memory by clicking the Load button in the Administration - Scheduling screen > Service Region List > Activities view. See Loading Activities for Service Regions for more information. Users can also freeze an activity's scheduled time or assignment. See Locking Schedules and Assignments (End User) for more information. CAUTION: Keep manual changes to a minimum. because the Optimizer works on the principles of constraint propagation and domain reduction, which are critical to solving complex schedules quickly. This means that no activity that violates a hard constraint can be loaded into the memory cache. (This includes implicit constraints—for example, using the employees' work schedules or excluding double-booking.) Reloading the ABS cache daily accomplishes the following:
To load employee and activity data for the service regions and reload the ABS and Optimizer caches, perform the following tasks:
Guidelines for Reloading Service Region DataIt is recommended that you follow these guidelines when reloading service region data:
See About Loading and Reloading Service Region Data for more background information. |
| Siebel Field Service Guide |
