Siebel Field Service Guide > Setting Up and Using Scheduling > Process of Setting Up SchedulingThe following list shows the procedures that administrators typically perform to set up scheduling within Siebel Field Service. Your company may follow a different process according to its business requirements. To set up and maintain scheduling, perform the following tasks:
See also About Troubleshooting the Appointment Booking System and Optimizer for more information about checks that you should carry out after performing the setup configuration. |
| Siebel Field Service Guide |
