Fundamentals > About the User Interface >
About Lists in the User Interface
A list consists of multiple records, presented as rows. Each record consists of multiple fields. You can select a record in a list by clicking any field in the record. This causes the record to be highlighted and adds an active record indicator to the left of the record. If the field you click is editable, it will go into edit mode and you can enter a value. An example of the active record indicator is shown in Figure 13; a list is shown in Figure 14.
Figure 13. Example of Active Record Indicator in List
Figure 14. Example of a List
To navigate in a list, you use the vertical and horizontal scroll bars. Topics in This Section
About Vertical Scroll Bars in Lists
About Horizontal Scroll Bars in Lists
About Show More and Show Less Buttons in Lists
Related Topic
Displaying Record Count
