Fundamentals > About the User Interface >
About the Link Bar in the User Interface
Screens contain sets of information shown in views. These views display data in different formats. For example, you can sometimes view the same data in a list, in an explorer view, or in a chart. You access views by clicking a hyperlink on the link bar, shown in Figure 12 for the Contacts screen. In the link bar, the active view appears in bold text (Contact Home in Figure 12). The link bar appears immediately below the screen tabs. If the view you need is not visible, click the down arrow at the end of the list to display and select another view (the down arrow appears to the right of the Consumer List hyperlink on the link bar in Figure 12). When you select another view, the last hyperlink on the link bar is replaced with the selected view.
Figure 12. Example of Link Bar and Drop-Down Arrow for Navigation
Related Topic
About Views and Subviews in the User Interface
