Bookshelf Home | Contents | Index | PDF | ![]() ![]() |
Fundamentals > About the User Interface > About Views and Subviews in the User InterfaceViews exist within screens and can contain lists, forms, charts, explorer views, and subviews. After identifying the desired screen and selecting the screen tab, you must decide what set of records you want to view in the selected screen. In many cases, a default set of records appears in a list below the screen tabs. If this is the case, you can use the visibility filter to access a different set of records. In some cases, a screen home page appears. You use view tabs after you have drilled down on the record you want to view or change. The view tabs show detailed presentations of data related to the selected record and screen. In some cases, subviews provide access to additional information about a record. Topics in This SectionRelated Topics |
Fundamentals |
