Fundamentals > About the User Interface > About Views and Subviews in the User Interface > About View Tabs in the User InterfaceView tabs appear in the lower part of the application window after you drill down on a record, as shown in Figure 9. The list of available views depends on which screen tab you have selected. Click a view tab to display the desired data for the record you have selected. For example, you may be looking at a contact in the Contacts screen. Clicking the Campaigns view tab displays the campaigns associated with this contact. If the view tab you need is not visible, use the drop-down arrow to display and select a different view tab. The drop-down arrow is located at the end of the currently displayed view tabs. It may also be that you do not have a certain view tab set to show in your user preferences. You may also use the Site Map to navigate to a desired view. If you select a view from the Site Map that does not appear as a view tab in your application, a view tab is created when you jump to that view. It will only be visible for the current session. Link BarIn some instances, a link bar may appear below the view tabs. This link bar provides access to additional views related to the selected record. Related Topics |
| Fundamentals |
