Fundamentals > Getting Started with Your Siebel Application >
Changing Browser Security Levels
If you want to use Microsoft Excel as your quick print application, you must change a security setting in your Web browser. To change your Web browser's security setting to use Microsoft Excel as your quick print application
- Start Internet Explorer.
- Choose Tools > Internet Options.
The Internet Options dialog box appears.
- Click the Security tab.
- Click the Custom Level button.
The Security Settings dialog box appears.
- Under Initialize and script ActiveX controls not marked as safe, select the Prompt option button.
- Click OK.
- At the Internet Options dialog box, click OK.
Related Topics
Setting Quick Print Options
Printing Records
