Table 22. Business Component Methods Syntax Summary
ActivateField Method |
Allows queries to retrieve data for the specified field. |
Dim busComp as SiebelBusComp BusComp.ActivateField(fieldName as String)
ActivateMultipleFields Method |
Allows queries to retrieve data for the fields specified in the property set. |
Dim busComp as SiebelBusComp busComp.ActivateMultipleFields(oPropSet as SiebelPropertySet)
Associate Method |
Creates a new many-to-many relationship for the parent object through an association business component. |
Dim busComp as SiebelBusComp busComp.Associate(whereIndicator as Integer)
BusObject Method |
Returns the business object that contains the business component. |
Dim busComp as SiebelBusComp Dim busObject as SiebelBusObject Set busObject = busComp.BusObject
ClearToQuery Method |
Clears the current query and sort specifications on the business component. |
Dim busComp as SiebelBusComp busComp.ClearToQuery
DeactivateFields Method |
Deactivates every currently activated field. |
Dim busComp as SiebelBusComp busComp.DeactivateFields
DeleteRecord Method |
Removes the current record from the business component. |
Dim busComp as SiebelBusComp busComp.DeleteRecord
ExecuteQuery Method |
Retrieves a set of BusComp records. |
Dim buscomp as SiebelBusComp buscomp.ExecuteQuery(cursorMode As Integer) As Boolean
ExecuteQuery2 Method |
Dim buscomp as SiebelBusComp buscomp.ExecuteQuery2(cursorMode As Integer,ignoreMaxCursorSize As Integer) As Boolean
FirstRecord Method |
Moves to the first record in the business component. |
Dim busComp as SiebelBusComp Dim bIsRecord as Boolean bIsRecord = busComp.FirstRecord
GetFieldValue Method |
Returns a value for the field specified in the argument. |
Dim busComp as SiebelBusComp Dim sValue as String sValue = busComp.GetFieldValue(FieldName as String)
GetFormattedFieldValue Method |
Returns a formatted value for the field specified in the argument. |
Dim busComp as SiebelBusComp Dim sValue as String sValue = busComp.GetFormattedFieldValue(FieldName as String)
GetLastErrCode Method |
Returns the most recent error code. |
Dim errCode As Integer Dim SiebApp as SiebelDataControl errCode=siebApp.GetLastErrCode
GetLastErrText Method |
Returns the most recent error text message. |
Dim busComp as SiebelBusComp Dim sErr as String busComp.GetLastErrText
GetMultipleFieldValues Method |
Returns a value for the fields specified in the property set. |
Dim busComp as SiebelBusComp busComp.GetMultipleFieldValues(oFieldNames as SiebelPropertySet, oFieldValues as SiebelPropertySet)
GetMVGBusComp Method |
Returns the MVG business component associated with the field specified in the argument. |
Dim busComp as SiebelBusComp Dim mVGBusComp as SiebelBusComp set mVGBusComp = busComp.GetMVGBusComp(FieldName as String)
GetNamedSearch Method |
Returns the argument-named search specification. |
Dim busComp as SiebelBusComp Dim sValue as String sValue = busComp.GetNamedSearch(SearchName as String)
GetPicklistBusComp Method |
Returns the pick business component associated with the field specified in the argument. |
Dim busComp as SiebelBusComp Dim pickBusComp as SiebelBusComp Set pickBusComp = busComp.GetPicklistBusComp(FieldName as String)
GetSearchExpr Method |
Returns the current search expression. |
Dim busComp as SiebelBusComp Dim sExpr as String sExpr = busComp.GetSearchExpr
GetSearchSpec Method |
Returns the current search specification for the field specified in the argument. |
Dim busComp as SiebelBusComp Dim sSpec as String sSpec = busComp.GetSearchSpec(FieldName as String)
GetUserProperty Method |
Returns the value of a named user property. |
Dim buscomp as SiebelBusComp Dim retStr as String retStr=buscomp.GetUserProp(prop As String) As String
GetViewMode Method |
Returns the visibility mode for the business component. |
Dim busComp as SiebelBusComp Dim iMode as Integer iMode = busComp.GetViewMode
InvokeMethod Method |
Calls the specialized method named in the argument. |
Dim busComp as SiebelBusComp Dim sReturn as String sReturn = busComp.InvokeMethod(methodName as String, methodArgs as String or StringArray)
LastRecord Method |
Moves to the last record in the business component. |
Dim busComp as SiebelBusComp Dim bReturn as Boolean bReturn = busComp.LastRecord
Name Method |
Returns the name of the business component. |
Dim busComp as SiebelBusComp Dim sName as String sName = busComp.Name
NewRecord Method |
Adds a new record to the business component. |
Dim busComp as SiebelBusComp busComp.NewRecord(whereIndicator as Integer)
NextRecord Method |
Moves to the next record in the business component. |
Dim busComp as SiebelBusComp bReturn as Boolean bReturn = busComp.NextRecord
ParentBusComp Method |
Returns the parent business component. |
Dim busComp as SiebelBusComp Dim parentBusComp as SiebelBusComp Set parentBusComp = busComp.ParentBusComp
Pick Method |
Places the currently selected record in a picklist business component into the appropriate fields of the parent business component. |
Dim busComp as SiebelBusComp busComp.Pick
PreviousRecord Method |
Moves to the previous record in the business component. |
Dim busComp as SiebelBusComp Dim bReturn as Boolean bReturn = busComp.PreviousRecord
RefineQuery Method |
Refines a query after a query has been executed. |
Dim busComp as SiebelBusComp busComp.RefineQuery
SetFieldValue Method |
Assigns a new value to the named field for the current row of the business component. |
Dim busComp as SiebelBusComp busComp.SetFieldValue(FieldName as String, FieldValue as String)
SetFormattedFieldValue Method |
Accepts the field value in the current local format and assigns the new value to the named field for the current row of the business component. |
Dim busComp as SiebelBusComp busComp.SetFormattedFieldValue(FieldName as String, FieldValue as String)
SetMultipleFieldValues Method |
Assigns a new value to the fields specified in the property set for the current row of the business component. |
Dim busComp as SiebelBusComp BusComp.SetMultipleFieldValues(oPropSet as SiebelPropertySet)
SetNamedSearch Method |
Sets a named search specification on the business component. |
Dim busComp as SiebelBusComp busComp.SetNameSearch(searchName as String, searchSpec as String)
SetSearchExpr Method |
Sets the search specification for the business component. |
Dim busComp as SiebelBusComp busComp.SetSearchExpr(searchSpec as String)
SetSearchSpec Method |
Sets the search specification for the specified field. |
Dim busComp as SiebelBusComp busComp.SetSearchSpec(FieldName as String, searchSpec as String)
SetSortSpec Method |
Sets the sort specification for a query. |
Dim busComp as SiebelBusComp busComp.SetSortSpec(sortSpec as String)
SetViewMode Method |
Sets the visibility type for the business component. |
Dim buscomp as SiebelBusComp Dim boolVal as Boolean boolVal=buscomp.SetViewMode(mode As Integer) As Boolean
UndoRecord Method |
Reverses any uncommitted changes made to the record. |
Dim busComp as SiebelBusComp busComp.UndoRecord
WriteRecord Method |
Commits to the database any changes made to the current record. |
Dim busComp as SiebelBusComp busComp.WriteRecord
