Table 46. WebApplet Events Summary
WebApplet_InvokeMethod Event |
Called after a specialized method or a user-defined method on the Web applet has been executed. |
WebApplet_InvokeMethod(MethodName as String)
WebApplet_PreCanInvokeMethod Event |
Called before the PreInvokeMethod, allowing the developer to determine whether or not the user has the authority to invoke the applet method. |
WebApplet_PreCanInvokeMethod(MethodName as String, &CanInvoke as String)
WebApplet_PreInvokeMethod Event |
Called before a specialized method for the Web applet is invoked or a user-defined method is invoked through oWebApplet.Invoke Method. |
WebApplet_PreInvokeMethod(MethodName as String)
WebApplet_Load Event |
Called just after an applet is loaded. |
WebApplet_Load
WebApplet_ShowControl Event |
Allows scripts to modify the HTML generated by the Siebel Web Engine to render a control on a Web page in a standard interactivity application. |
WebApplet_ShowListColumn Event |
Allows scripts to modify the HTML generated by the Siebel Web Engine to render a list column on a Web page in a standard interactivity application. |
