Table 78. PropertySet Methods Syntax Summary
AddChild Method |
Adds subsidiary property sets to a property set. |
var oPropSet; var iIndex; iIndex = oPropSet.AddChild( childObject);
Copy Method |
Returns a copy of a property set. |
var oPropSet1; var oPropSet2; oPropSet2 = oPropSet1.Copy();
GetChild Method |
Returns a specified child property set of a property set. |
var oPropSet; var sPropVal; sPropVal = oPropSet.GetChild(index);
GetChildCount Method |
Returns the number of child property sets attached to a parent property set. |
var oPropSet; var iCount; iCount = oPropSet.GetChildCount();
GetFirstProperty Method |
Returns the name of the first property in a property set. |
var oPropSet; var sPropName; sPropName = oPropSet.GetFirstProperty();
GetNextProperty Method |
Returns the name of the next property in a property set. |
var oPropSet; var sPropName sPropName = oPropSet.GetNextProperty();
GetProperty Method |
Returns the value of a property when given the property name. |
var oPropSet; var sPropVal sPropVal = oPropSet.GetProperty(propName);
GetPropertyCount Method |
Returns the number of properties attached to a property set. |
var count; count = oPropSet.GetPropertyCount();
GetType Method |
Returns the value stored in a type in a property set. |
var oPropSet; var sTypeVal sTypeVal = oPropSet.GetType(value);
GetValue Method |
Returns a value stored as part of a property set. |
var oPropSet; var sValVal; sValVal = oPropSet.GetValue(value);
InsertChildAt Method |
Inserts a child property set into a parent property set at a specific location. |
var oPropSet; oPropSet.InsertChildAt(childObject, index);
PropertyExists Method |
Returns a Boolean value indicating whether the property specified in the argument exists. |
Dim oService as SiebelService Dim propExists as Boolean propExists = oService.PropertyExists(propName as String)
RemoveChild Method |
Removes a child property set as a specified index from a parent property set. |
var oPropSet; oPropSet.RemoveChild(index);
RemoveProperty Method |
Removes the property specified in its argument from a property set. |
var oPropSet; oPropSet.RemoveProperty(propName);
Reset Method |
Removes every property and child property set from a property set. |
var oPropSet; oPropSet.Reset();
SetProperty Method |
Assigns a value to the property of a property set specified in its argument. |
var oPropSet; oPropSet.SetProperty (propName, propValue);
SetType Method |
Assigns a data value to a type member of a property set. |
var oPropSet; oPropSet.SetType(value);
SetValue Method |
Assigns a data value to a value member of a property set. |
var oPropSet; oPropSet.SetValue(value);
