Pricing Administration Guide > Creating Attribute Adjustments >
Process of Creating an Attribute Adjustment
To create attribute adjustments, perform the following tasks:
- Adding an Attribute Adjustment Record
- Specifying Attribute Adjustment Dimensions and Domains
- Adding Attribute Adjustment Conditions
- Associating Attribute Adjustments with Price List Line Items
NOTE: Before you can perform this process, you must set up the appropriate variable maps, as described in Using Variable Maps in Attribute Adjustments.
