Siebel Installation Guide for Microsoft Windows: Servers, Mobile Web Clients, Tools > Configuring the RDBMS > Configuring MS SQL Server for Siebel Applications > Guidelines for Selecting a Language for MS SQL ServerAs part of database creation, you must set the language characteristics of your database, even if you deploy in only one language. See also Planning RDBMS Installation and Configuration and Specifying the Locale for Siebel Applications. See also Verifying System Preferences and Other Settings for Database Code Page. Sort OrderThe sort order is a characteristic that requires special consideration regarding the Siebel Database. On MS SQL Server, the sort order of a database instance is specified during database creation and defines the way in which the instance will sort character data. Although each SQL Server system database and each object within a database can have its own unique sort order, you should set the sort order at the database instance level only. The Siebel application's support for a given sort order depends both on the code page of the database and on whether it will be used in a development or a production environment. For more information on supported sort orders, see System Requirements and Supported Platforms on Siebel SupportWeb.
| Siebel Installation Guide for Microsoft Windows: Servers, Mobile Web Clients, Tools |
