Siebel Installation Guide for Microsoft Windows: Servers, Mobile Web Clients, Tools > Configuring the RDBMS > Configuring MS SQL Server for Siebel Applications > Guidelines for Creating the MS SQL Server DatabaseTo help you create your database instance, Siebel Systems provides a list of supported MS SQL Server code pages in System Requirements and Supported Platforms on Siebel SupportWeb. Use a small, nonproduction environment for testing purposes. After you install the Siebel Database Server files on the Siebel Server machine, as described in Installing the Siebel Database Server and Configuring the Siebel Database you may modify the database table and index creation scripts to specify the table space names you created for Siebel tables and indexes. For more information, see Guidelines for Overriding MS SQL Server Default Table Spaces for Database Objects. |
| Siebel Installation Guide for Microsoft Windows: Servers, Mobile Web Clients, Tools |
