Table 7. Screens Menu Options
Application Upgrader |
Application Upgrade Attribute List |
The Application Upgrades and Attribute Differences lists appear in the Object List Editor. |
Application Upgrade Database Version |
For internal use by Siebel Systems. |
Application Upgrade Object List |
The Application Upgrades, Object Differences, and Attribute Differences lists appear in the Object List Editor. |
System Administration |
List of Values |
Displays lists of values in the development database. |
Strings |
Siebel Systems internal use only |
System Preferences |
Displays system preferences in the Object List Editor. This information is similar to the System Administrator View available from the Administration - Application screen in Siebel Business Applications. System Preferences is used by the src\server\sfs\common\locate_fulfill\cssconfigagent.cpp file. The system preference is used by fulfillment and part locator engines for cleaning the rows in a temporary table that is shared by the client and server components. The parameter is only used when you want to clean up the temporary table. In that case, you must explicitly submit a CleanUp request to fulfillment/part locator engines. |
