Using Siebel Tools > About the Siebel Tools User Interface > About the Siebel Tools Menu Bar >
Go Menu
The Go menu contains options for moving through a records list. Primarily, you use the Go menu to create and navigate to bookmarks, which flag objects for easy return navigation. Bookmarks are a helpful navigation aid, allowing you to move around among the objects of different types you are working on. Table 8 describes the Go menu options.
Table 8. Go Menu Options
Back |
Returns to the previously displayed screen. |
Forward |
Returns to subsequently displayed screen. |
Previous Record (CTRL+UP) |
Goes to the objects above the current selection. |
Next Record (CTRL+DOWN) |
Goes to the objects below the current selection. |
First Record (CTRL+PGUP) |
Goes to the first objects in the list. |
Last Record (CTRL+PGDN) |
Goes to the last objects in the list. |
Add Bookmark |
Invokes the Add Bookmark dialog box, for creation of a bookmark to the currently selected objects. |
Bookmark List |
Opens the Bookmarks dialog box, for selection of an existing bookmark to navigate to. You can also use this dialog box to rename or delete existing bookmarks. |
