Using Siebel Tools > About the Siebel Tools User Interface > About Siebel Tools Toolbars >
Edit Toolbar
The Edit toolbar contains edit tools, the New Object wizard, and undo and redo options. You can also display a menu of edit tools by selecting a field and right-clicking while the cursor is positioned over the Object List Editor. For more information, see About Siebel Tools Right-Click Menus. Table 14 describes the Edit toolbar buttons.
Table 14. Edit Toolbar Buttons
New |
Invokes the New Object Wizard, which allows you to create applets, views, charts, and other objects. |
Save |
Saves changes in the current editing window when you are editing Layout, Menu, or Basic Scripts. |
Save All |
Saves changes in all open editing windows. |
Cut |
In a text property, copies the selected text to the clipboard and deletes the existing text. In the Applet Designer, copies the selected control to the clipboard and deletes the existing control. |
Copy |
In a text property, copies the selected text to the clipboard without deleting it. In the Applet Designer, copies the selected control to the clipboard without deleting it. |
Paste |
Inserts text from the clipboard into a text property at the insertion point. In the Applet Designer, inserts a control from the clipboard. |
Undo |
Reverses the last change to a property value in the Object List Editor or Property window if the object has not been committed. |
Redo |
Reapplies changes after the Undo command has been executed. |
