Using Siebel Tools > About the Siebel Tools User Interface > About Siebel Tools Toolbars >
History Toolbar
The History toolbar contains buttons for retracing your steps and for creating and navigating to bookmarks, which flag objects for quick return navigation. Bookmarks are a helpful navigation aid, allowing you to move around quickly among the different object types with which you are working. Table 15 describes the History toolbar buttons.
Table 15. History Toolbar Buttons
Go Back |
Returns to the previously displayed screen. |
Go Forward |
Returns to the subsequent displayed screen. |
Add Bookmark |
Opens the Add Bookmark dialog box, so you can add a bookmark for the currently selected object. |
Bookmark List |
Opens the Bookmarks window, so you can select a bookmark to navigate to. You can also use this window to rename or delete existing bookmarks. |
