Use the information in the following table to set your options, and then click OK.
Option
Description
Developing for deployment on DB2 for zSeries
For information about this parameter, see Implementing Siebel Business Applications on DB2 UDB for z/OS.
Allow to create column of type 'Character' being greater than 1
Removes constraint on columns of type CHAR, so that they can be greater than one character in length. Note that defining a column as CHAR when the data being stored can be variable in length causes the data to be padded with blank spaces in the database.
