Using Siebel Tools > Managing Repositories > About Repository Patch FilesA repository patch file, like an archive file, consists of exported objects. The difference between a patch (SPF) file and an archive (SIF) file is that the patch file contains two versions of each object, one from the preupgrade source repository and one from the postupgrade. An archive file contains only one version of each object, and all objects are from the same repository. For information on archive (SIF) files, see About Archive Files. Figure 24 shows how pre- and postupgrade versions of an object are paired in the patch file, and then used when applying the patch to the target repository. The pair of pre- and post-release objects in the patch file provide before and after snapshots of the object. The patch application process considers both when determining what changes to make to the target repository. Related Topics |
| Using Siebel Tools |
