Using Siebel Tools > Managing Repositories >
Exporting and Importing Repositories Using the Database Configuration Utility
To export and import the entire repository, you use the Database Configuration Utility. This is typically used for backing up and restoring and for moving the contents of a repository to a repository in an another environment, when both the source and the target environment have the same physical database schema and Siebel release version. When importing and exporting using the Database Configuration Utility, consider the following:
NOTE: When exporting a repository in a Windows or UNIX environment using the Export Repository option of the DB Server Configuration wizard, the log files are placed in following directories:
- Siebel_Server\log\exprep\output
- Siebel_Server\log\exprep\state
NOTE: The value "exprep" is the default process name for the exprep utility. You can change this value to facilitate ease of use.
For information on importing or exporting repositories, see To import or export a repository in a Windows environment or To import or export a repository in a UNIX environment depending on your operating system. The To import or export a repository in a Windows environment procedure applies to importing or exporting a repository, although it presents only the importing case. Exporting is similar, in that you identify the repository to export instead of the one to import. When exporting a repository using Configure DB Server, all the values specified in the dialog boxes are written to the SIEBEL_SERVER_ROOT\master_exprep.ucf file. After the parameters are collected, you are prompted to execute the export now or not. If you choose to not export now, you can execute the export later by running the following command in the DOS window: siebupg.exe /m master_exprep.ucf
- Launch the Database Server Configuration Utility by choosing Start > Programs > Siebel Enterprise Server version_number > Configure DB Server.
The Gateway Name Server Address dialog box appears.
- Specify your Gateway Server Address and Enterprise Server Name and then click Next.
The Installation and Configuration Parameters: Siebel Server Directory dialog box appears.
- In the Siebel Server Directory dialog box, either accept the default value or click Browse to select a directory, and then click Next.
The Installation and Configuration Parameters: Siebel Database Server Directory dialog box appears.
- Either accept the default value, or click Browse to select a directory, and then click Next.
The Siebel Database Server Options: Siebel Database Operation dialog box appears.
- In the list of operations, select Import/Export Repository and then click Next.
The Import Repository Parameters: Select Repository Operation dialog box appears.
- Select Import Repository, and then click Next.
You can also choose the following options: Add language to an existing Repository, or Export Repository.
The Import Repository Parameters: Import Selection dialog box appears.
- Select one of the following, and then click Next:
- Select Import Standard Repository to select which language string to import.
This option is useful when more than one base language is to be implemented.
NOTE: You can only select one language string to import.
- Select Import Custom Repository to import all the languages found in the repository.dat file.
The following succession of dialog boxes appears:
Installation and Configuration Parameters: Language Selection |
Select a language and click Next. English is the default language. |
Installations and Configuration Parameters: RDBMS Platform |
Select an RDBMS Platform. |
Installation and Configuration Parameters: ODBC Data Source Name |
Select the ODBC Data Source Name. |
Installation and Configuration Parameters: Database User Name |
Select the Database User Name and Database Password. |
Installation and Configuration Parameters: Database Table Owner |
Select the Database Table Owner and Database Table Owner Password. |
Installation and Configuration Parameters: Import Repository Name |
Select the name of the repository that you want to import and the filename from which you are importing. This will be the name given to the imported repository. |
- In the Configuration Parameter Review, review the list of parameters you entered and then accept the configuration by clicking Finish.
- Run the following command:
$SIEBEL_ROOT/siebenv.sh (source $SIEBEL_ROOT/siebenv.csh)
By convention, $SIEBEL_ROOT is the absolute path to the Siebel Server installation directory (siebsrvr).
LANGUAGE should be set to the language in which the Configuration Wizard prompts appear; for example, enu for U.S. English.
If either of these values is incorrect or empty, reset them using one of the following commands, as appropriate to the shell you use.
C |
setenv LANGUAGE New Value
Korn |
export LANGUAGE|SIEBEL_ROOT=New Value
- Set an appropriate level of detail in the log file for this activity.
C |
setenv SIEBEL_LOG_EVENTS trace3
Korn |
export SIEBEL_LOG_EVENTS trace3
- Navigate to $SIEBEL_ROOT/
bin and enter:
dbsrvr_config.ksh
This launches the Database Server Configuration utility.
- When prompted for the Siebel Server installation directory, either accept the default value or enter a new directory.
If either the SIEBEL_ROOT or LANGUAGE value is not set or is incorrect, you must correct them before proceeding.
- When prompted to select the Siebel Database Operation, select Import/Export Repository.
- Choose Import Repository.
- Choose Import Standard Siebel Repository or Import Custom Repository.
- The following succession of prompts appears.
Select a language. English is the default language. |
RDBMS Platform |
Select the name of the repository that you want to import and the filename from which you are importing. |
- Review the list of parameters, and then accept the configuration by entering Y.
RDBMS Platform |
Select a RDBMS Platform. |
Select name of the repository that you want to import and the filename from which you are importing. |
Configuration Parameter Review |
Summary dialog box gives a list of your choices. You can accept the configuration by entering Y. |
NOTE: You follow the same procedure for Export Repository except that you choose export instead of import in Step 6.
