Using Siebel Tools > Working with Objects >
About the Validation Options Dialog Box
The Validation Options Dialog box appears when you click the Options button in the Validate dialog box. Figure 17 shows an example of the Validation Options dialog box.
Figure 17. Validation Options Dialog Box
Table 29 describes each user interface element of the Rules area of the Validation Options dialog box. The repository Validator must be used only in conjunction with the Time Filter, to avoid validating objects that are not being used.
Table 29. User Interface Elements of the Rules Area of the Validation Options Dialog Box
Rules list |
Lists all rules that can be enforced during validation. Each row in the list identifies a rule for a specific object type (or All). You can sort the rows by by clicking a column heading. You can also resize columns by dragging the right or left border of the heading cell. |
Severity column |
An icon appears in this list column for each rule. It indicates whether the rule generates a warning (yellow icon with an exclamation point) or an error (red icon with a minus sign). |
Rule column |
The integer value that identifies this rule. |
Object columns |
Either the single object type that this rule applies to, or All. |
Description column |
The description of the rule. |
Enforce |
A Yes or No value for each rule. Yes validates all objects of the object type identified in the Object column. Yes/No values in this list column are changed using the Enforce, Ignore, Enforce All, and Ignore All buttons. |
Save button |
Saves the current set of rules and their state (enforced or ignored) to a text file you specify. Other settings are saved to the preferences file when you press ENTER. |
Enforce button |
Changes the Enforce column value in the selected row from No to Yes. |
Ignore button |
Changes the Enforce column value in the selected row from Yes to No. |
Enforce All button |
Changes all values in the Enforce column to Yes. |
Ignore All button |
Changes all values in the Enforce column to No. This has the effect in the next validation of not validating any objects. |
Details text box |
The full text of the rule description for the currently selected row in the Rules list. |
Table 30 describes the Time Filters area of the Validation Options dialog box.
Table 30. User Interface Elements of the Time Filter Area of the Validation Options Dialog Box
Last validated check box and date field |
When selected, validates only objects changed since the date you enter into the corresponding date box. |
Custom check box and date and time fields |
When selected, validates only objects changed within the date range you enter into the corresponding date boxes. |
Table 31 describes the check boxes in the Action area of the Validation Options dialog box.
Table 31. User Interface Elements of the Action Area of the Validation Options Dialog Box
Do not report warnings check box |
When selected, reports errors only, not warnings. It also changes the Enforced setting of all warning rules to No. |
Abort validation after check box and text box |
When selected and a number is entered in the text box, Siebel Tools stops validating after the specified number of errors is reached. By default, the validation process continues to run until it is completed or canceled. |
