Using Siebel Tools > Working with Objects > Using Queries to List ObjectsYou can use query-by-example (QBE) to narrow the list of objects displayed in the Object List Editor. An Object List Editor query searches for objects based on values in one or more properties of the object. The queries can be simple, one-condition queries or compound, multiple-condition queries. You can create, refine, and activate queries from the Query menu or from the List toolbar. (Refine means to impose a further restriction on the current Object List Editor query by running it again with an additional constraint.) To create and execute an Object List Editor query
To restore the Object List Editor to its prequery state
Related Topics |
| Using Siebel Tools |
