Table 32. Simple Query Operators
Equal to |
Less than |
Greater than |
Not equal to |
Less than or equal to |
Greater than or equal to |
Any number of characters (including none) may take the place of the asterisk (*) |
Any one character matches the question mark (?) |
IS NOT NULL |
Searches for nonblank fields |
IS NULL |
Searches for blank fields |
LIKE |
Searches for values starting with the indicated string |
NOT LIKE |
Searches for values not starting with the indicated string |
Searches for strings that contain special characters, such as a comma (,) |
EXISTS ( ) |
Searches for values in a multi-value group |
Forces the case of the text string to whatever follows the tilde (~) |
