Siebel Hospitality Guide > Setting Up Charge Codes, Taxes, and Service Charges > Service Charge Administration >
Creating a Service Charge
Use the following procedure to define service charges for the property. This task is performed as part of Service Charge Administration, which is a step in Process of Setting Up Charge Codes, Taxes, and Service Charges. To create a service charge
- From the application-level menu, choose View > Site Map > Tax Service Admin > Service Charges.
- In the Service Charges list, create a new record.
- Complete the fields and save the record.
The following table describes some of the fields.
NOTE: You can enter data in either the Amount or Percent field, but not both.
Name |
The name of the service charge. |
Description |
The description of the service charge. |
Percent |
Service charge based on a percentage. The service charge amount is based on this percent value multiplied by the price for the line item. |
Amount |
Service charge based on a flat fee. The flat fee is a preset amount. |
Start Date |
Date the service charge becomes active. |
End Date |
Date the service charge becomes inactive. |
Currency |
The monetary unit of measure. |
Taxable |
Check box that indicates whether or not the service charge is taxable. |
- If the service charge is taxable, click the check box in the Taxable field, and then click the Taxes view tab.
- In the Taxes list, click New, and from the Add Taxes dialog box select the tax and click OK.
NOTE: The Taxable flag is for informational purposes only.
