Siebel Hospitality Guide > Generating Event Checks > Voiding an Event CheckSince posted event checks can no longer be updated, if, during a review, the manager finds a problem with an event check, then the manager must void the original event check and post an updated version. When the event manager sets the event check status to Void, the Order screen's Function Line Items view appears with a new version of the event check. The copy of the voided event check has a new Event Check number and can be edited. The status of the order is updated from Closed to Open, and the Event Check # field reflects the new invoice number. This task is a step in Process of Generating Event Checks.
| Siebel Hospitality Guide |
