Siebel Hospitality Guide > Generating Event Checks > Generating an Event CheckOperations managers and event managers can generate an Event Check for an individual event order record, or all orders that occur on a specified day. When an Event Check is opened, the status of the event order is set to Event Check, an event check header is created, and the Event Check # field is populated with a unique identifier. The Event Check # includes a link to the Event Checks screen, which provides more detail on the generated event check. Only one event check can be opened for each order record; subsequent attempts to open an event check result in an error message. This task is a step in Process of Generating Event Checks. To generate an event check for an individual order
To generate an event check for all orders in a day
| Siebel Hospitality Guide |
