Siebel Hospitality Guide > Setting Up Products and Assets >
Creating Property-Specific Products
Use the Product Administration screen to create property-specific products. This task is a step in Process of Setting Up Products and Assets. To create a property-specific product
- From the application-level menu, choose Navigate > Site Map > Product Administration.
- In the Products list, create a new record.
- Complete the appropriate fields and save the record.
The following table describes some of the fields.
Name |
The product name. |
Part # |
The part number for the product. |
Type |
The type of product. Examples are Menu, Package, Sleeping Room, and Setup Style. |
Organization |
Automatically populated with the name of the default organization. The user can change the selection or add more than one organization, designating one organization as the primary. |
UoM |
The unit of measure used for the product. For example, if coffee is the product, the unit of measure might be pounds. |
Child Category |
The sub category for the product. |
Category |
This field is automatically populated after a subcategory is specified. |
Parent Category |
If a category hierarchy is involved, this is the top-level category. |
Resource Type |
Designates whether the product is critical, Non Critical, or General. |
Property |
The property associated with the product. |
