Sun Master Index Configuration Reference
Master Index Field Notations
The configuration files use specific notations to define a specific field or a group of fields in an enterprise or system object. There are three different types of notations used by Sun Master Index.
The following topics describe each type of notation used:
ePath Notation
In update.xml, an element path, called an ePath, is used to specify the location of a field or list of fields. ePaths are also used in the StandardizationConfig element of mefa.xml. An ePath is a sequence of nested nodes in an enterprise record where the most nested element is a data field or a list of data fields. ePaths allow you to retrieve and transform values that are located in the object tree.
ePath strings can be of four basic types:
A context node is specified when evaluating each ePath expression. The context is considered as the root node of the structure for evaluation.
These topics describe and illustrate how to form ePath strings:
ePath Syntax
The syntax of an ePath consists of three components: nodes, qualifiers, and fields, as shown below.
node{.node{”[”qualifier’]’}+}+.field
ePath Notation Example
The following sample illustrates an object structure containing a system object from Site A with a local ID of 111. The object contains a first name, last name, and three addresses. Following the sample, there are several ePath examples that refer to various elements of this object structure along with a description of the data in the sample object structure referred by each ePath.
Enterprise
   SystemObject - A 111
      Person
         FirstName
         LastName
         -Address
            AddressType = Home
            Street = 800 Royal Oaks Dr.
            City = Monrovia
            State = CA
            PostalCode = 91016
         -Address
            AddressType = Office
            Street = 181 2nd Ave..
            City = Monrovia
            State = CA
            PostalCode = 91016
         -Address
            AddressType = Billing
            Street = 100 Grand Avenue
            City = El Segundo
            State = CA
            PostalCode = 90245
Qualified Field Name Notation
In query.xml and the MatchingConfig element of mefa.xml use qualified field names to specify the location of a field. This method defines a specific field and is not used to define a list of fields. A qualified field name is a sequence of nested nodes in an enterprise record where the most nested element is a data field.
There are two types of qualified field names.
The following topics describe and illustrate how to form qualified field name strings.
Qualified Field Name Syntax
The syntax of a fully qualified field name is:
Enterprise.SystemSBR.parent_object.child_object.field_name
where parent_object refers to the name of the parent object in the index, child_object refers to the name of the child object that contains the field, and field_name is the full name of the field. If the parent object contains the field being defined, the child object is not required in the path.
The syntax of a qualified field name is:
Qualified Field Name Example
The following sample illustrates an object structure that could be defined in object.xml. The object contains a Person parent object, and Address and Phone child objects.
Person
   FirstName
   LastName
   DateOfBirth
   Gender
   -Address
      AddressType
      StreetAddress
      Street
      City
      State
      PostalCode
   -Phone
      PhoneType
      PhoneNumber
The following fully qualified field names are valid for the sample structure above.
The qualified field names that correspond with the fully qualified names listed above are:
Simple Field Name Notation
In midm.xml, simple field names are used to specify the location of a field that appears on the MIDM. These are used in the GUI configuration section of the file. Simple field names define a specific field and are not used to define a list of fields. They include only the field name and the name of the object that contains the field. Simple field names allow you to define fields within the context of an object.
The following topics describe and illustrate how to form simple field notations:
Simple Field Notation Syntax
The syntax of a simple field name is:
object.field_name
where object refers to the name of the object that contains the field being defined and field_name is the full name of the field.
Simple Field Notation Example
Person
   FirstName
   LastName
   DateOfBirth
   Gender
   -Address
      AddressType
      StreetAddress
      Street
      City
      State
      PostalCode
   -Phone
      PhoneType
      PhoneNumber
The following simple field names are valid for the sample structure above.
