Sun Master Index Configuration Reference
Query Configuration
In query.xml, you configure properties of the Query Builder, which is a class that uses defined criteria and options to generate queries and query results from a master index database. The criteria and options used by the Query Builder to create database queries are defined in query.xml. The criteria must be fields that are defined in the Object Definition, and the options are key and value pairs that fine-tune the query operation. You can define the characteristics of the searches performed from the Master Index Data Manager and of the queries used by the master index application to search for a candidate pool of potential matches for incoming records.
The following topics provide information about queries and the structure of query.xml:
Query Builder Components
The master index application performs two types of queries. Users perform manual queries from the MIDM and the master index application automatically performs queries before processing matches for an incoming record. Two types of queries, basic queries and blocking queries, are predefined in the Query Builder. By default, basic queries are defined for the MIDM and blocking queries are defined for match processing, though this is not required. You can also use a blocking query for the phonetic searches performed from the MIDM. Both types of queries are configured by query.xml, and custom queries can be created and implemented with the master index application.
You can configure certain query properties. You can configure both basic and blocking queries to search on standardized or phonetic versions of the search criteria, and you can also specify that they search on exact values or a range of values. Basic queries can be configured to allow wildcard characters. For the blocking queries, you define the criteria to include in each block of query criteria.
The following topics provide additional information about the different types of queries:
Basic Queries in a Master Index
By default, searches performed from the MIDM follow the logic defined in the configured basic queries. You can specify which query type to use for each search defined for the MIDM (this is specified in midm.xml). These searches can be weighted, which means that the match engine calculates the likelihood that the search results match the actual search criteria and assigns a matching weight to each returned record. You can specify whether the search is performed on the original or phonetic version of the criteria.
The basic query uses all supplied search criteria to create a single SQL query. For this query, each field in the WHERE clause is joined by an AND operator, meaning that only records that match on all search fields are returned. This query has an option to allow wildcard characters in the search criteria (a percent sign (%) indicates multiple unknown characters). When this option is set to true, the query uses the LIKE operator rather than EQUALS. This option allows you to search by criteria for which you have incomplete data.
The searches performed from the MIDM can be further customized in midm.xml (for more information, see Master Index Data Manager Configuration).
Blocking Queries in a Master Index
When the master index application evaluates possible matches of records sent to the master index application from external systems and from the MIDM, the index performs a set of predefined SQL queries to retrieve a subset of possible matches. These queries are known as blocking queries. The matching algorithm processes the input record against the profiles retrieved from the blocking query (known as the candidate pool) and assigns them matching probability weights.
Blocking Query Block Processing
In query.xml, you define the criteria and conditions for querying the database to retrieve the subset of possible matches to the incoming record, including hints. You can define multiple queries, known as blocks, for each blocking query, and the master index application performs each of these queries in turn until sufficient records are retrieved (called a match pass). Using the default Query Builder, a block is only processed if the search criteria include all of the fields defined for that block. Each field in a block is joined by an AND operator in the WHERE clause, and each block is joined by a UNION operator. This type of search can also be used as a phonetic search in the MIDM.
Blocking Query for Matching
The blocking queries you define here are referenced in master.xml, which specifies which one of the defined blocking queries to use for match processing. They might also be referenced in midm.xml if a blocking query is used for phonetic searches from the MIDM. To enable extensive searching (that is, searching against additional tables, such as an alias table for a person index), you must add the fields from that table to the blocking query.
Certain fields used as criteria in the blocking query might contain known default or invalid values. You can define exclusion lists to filter out unwanted or invalid values from the blocking query. For more information, see SBR, Matching, and Blocking Filter Configuration.
Phonetic Queries in a Master Index
You can configure both basic queries and blocking queries to perform phonetic searches from the MIDM. If you use a basic query, then all entered criteria must match existing records in order to return results from the search. If you use a blocking query, several queries are performed using different combinations of data until enough matching records are returned or until all defined combinations have been tried.
For example, if you use a basic query and enter first and last name, date of birth, gender, and SSN for criteria, the basic query might not return any matches if any one of those fields does not match the criteria. However, if you use a blocking query for the same example, it might search on SSN, then on first name and date of birth, and then on last name and gender. The query returns any matching records from any of the query passes.
Range Searching
Both basic and blocking queries can be configured to perform exact searches or range searches. An exact search performs a query for the exact value entered into a field as search criteria; range searches perform a query on a range of values based on the value entered into a field as search criteria. The basic query supports standard range searching, where both the lower and upper limits of the range is supplied. The blocking query supports standard range searching plus two additional types that use predefined offset values or constants.
Offset values allow you to specify values to be added to or subtracted from the entered value to determine the range on which to search. Constants provide a default value to use as a range when no value is entered or when incomplete information is available.
Range searching is configured in both midm.xml and query.xml. The processing logic for different types of range searching is described in Range Search Processing.
The query.xml File
The properties for the predefined queries are defined in query.xml. Some of the information entered into the default configuration file is based on the fields you specified for blocking in the wizard, and some is standard across all implementations. For most implementations, this file will require some customization.
The following topics provide information about working with query.xml:
Modifying query.xml
You can modify query.xml at any time, but you must regenerate the application and redeploy the project after making any changes to the file. The properties of the blocking query used by the match process should not be modified after moving into production because it can cause unexpected matching weight results. The possible modifications to this file are restricted by the schema definition, so be sure to validate the file after making any changes. Most of the components in this file can be configured using the Configuration Editor, which simplifies the process of defining queries by providing a graphical interface to perform the required tasks.
The query.xml File Structure
This topic describes the structure of the XML file, including general requirements and constraints, and provides a sample implementation.
query.xml File Description
Table 2 lists each element in query.xml and provides a description of each element along with any requirements or constraints for each element.
Table 2 query.xml File Structure
Element/Attribute
Description
QueryBuilderConfig
The configuration class for the query builders. This should not be modified.
query-builder
A list of query definitions. This element defines each query and the attributes of each query.
query-builder/name
A unique ID for the element. This element is used to identify the Query Builder and is referenced from midm.xml when specifying the query to use on a search page. It is also referenced from mefa.xml when specifying the query to use for matching. No spaces are allowed in this attribute.
query-builder/class
The fully qualified name of the query class. Two default Query Builder classes are provided.
  • com.sun.mdm.index.querybuilder.BasicQueryBuilder – Builds dynamic queries using all the available input fields. When configured to use normalized and phonetic data, this query performs phonetic searches; when configured not to use normalized and phonetic data, this query is used for exact alphanumeric searches.
  • com.sun.mdm.index.querybuilder.BlockerQueryBuilder – Builds queries using the criteria defined in the block definitions defined for the query. When a blocking query is performed, the application searches only on the blocks for which the query has complete data.
query-builder/parser-class
The fully qualified name of the class that parses the config elements for each query. This should not be modified for the default queries.
query-builder/standardize
An indicator of whether the query criteria is standardized before being passed to the query. Specify true if any fields are standardized for the query; specify false if no fields are standardized for the query.
query-builder/phoneticize
An indicator of whether the query criteria is phonetically encoded before being passed to the query. Specify true if any fields are phonetically encoded for the query specify; false if no fields are phonetically encoded for the query.
config
The configuration information for a query. Each query-builder element contains one config element.
option
One query parameter, specified by key and value attributes, as described below. This is only used by basic queries; blocking queries do not use this element.
option/key
A parameter for the query option. For the default basic query, only the UseWildCard key is available.
option/value
The value of the key specified by the corresponding key attribute. For the default option, UseWildCard, specify true to allow wildcard characters for that query type; otherwise specify false. When wildcard characters are enabled, you can enter a percent sign (%) to indicate multiple unknown characters.
block-definition
A list of database hints and defined query criteria blocks, which are identified by unique ID numbers.
block-definition/number
An attribute of the block-definition element that specifies the unique ID number of each query block. Each block defined for the blocking query must be identified by a unique ID.
hint
A hint to add to the query to help optimize query execution. Hints are especially useful when a blocking query uses only child object fields; the hint can specify to scan the child object table first. This element is optional. For SQL Server, only OPTION hints are supported.
block-rule
A list of fields to be included in each query block, including indicators of whether a range is to be used and, if so, what type of range search to perform.
type of search
An indicator of the type of search to perform on the field defined in the following elements. Each type of search element defines one field in a block-rule element; that is, one field in a query block. This element includes a field element, a source or constant element, and, for range searches only, a default element that defines lower and upper bounds.
Specify one of the following types.
  • equals - Performs an exact search against either the criteria or the value defined for the constant element.
  • not-equals - Searches for values that do not equal either the criteria or the value defined for the constant element.
  • greater-than-or-equal - Performs a search for values that are greater than or equal to either the criteria or the value defined for the constant element.
  • less-than-or-equal - Performs a search for values that are less than or equal to either the criteria or the value defined for the constant element.
  • range - Performs a search against a range of either static or user-defined ranges. If you select this option, you must specify upper and lower bounds in a default element.
Tip –
If a field is to be used for simple range searching (where the user or incoming message supplies lower and upper limits of the range are supplied) be sure to define that field for range searching in midm.xml for the searches that use this query. For more complex range searches that use offset values or constants instead of user-supplied limits, do not define the field for range searching in midm.xml.
field
The fully qualified field name of the field to be included in the query block (for example, Enterprise.Person.Address.AddressLine1).
source
The qualified field name of the source field in the object from which the criteria is obtained (for example, Person.Address.AddressLine1). An asterisk (*) can be used as a wildcard character. If the criteria should be a constant value instead of being supplied by a user or incoming message, define a constant element instead of a source element.
Tip –
When a field in a child object is defined for a blocking query, use the asterisk wildcard character in the ePath to the source field to ensure all instances of the child object in an incoming message are used as search criteria. Each instance is joined by an OR operator. For example, this configuration:
<field>Enterprise.SystemSBR.Person.Alias.FirstName
</field>
<source>Person.Alias[*].FirstName</source>
would result in a WHERE clause similar to this:
WHERE Alias.FirstName=”Meg” OR Alias.FirstName=”Maggie”
constant
A constant value that provides the criteria for a search. Define this element instead of a source element if the criteria is a constant rather than being user defined. You can use a constant value with the following types of queries: equals, not-equals, greater-than-or-equals, and less-than-or-equals.
default
A list of upper and lower limits defining a range search. If no limits are defined, the search is a simple range search in which the upper and lower values are supplied by the user or the incoming message (for example, in “Date of Birth From” and “Date of Birth To” fields).
lower-bound
The lower limit of a constant or offset range search. Use a negative number for the lower limit of an offset search. This number is added to the value supplied for the search to determine the lower limit of the range. The value can be numeric, date, or string. See Range Search Processing for more information.
lower-bound/type
The type of range search. Define the type attribute as offset to use an offset value or as constant to define a lower constant.
upper-bound
The upper limit of a constant or offset range search. The value can be numeric, date, or string. See Range Search Processing or more information.
upper-bound/type
The type of range search. Define the type attribute as offset to use an offset value or as constant to define an upper constant.
query.xml Example
Below is a sample illustrating the elements in query.xml.
<QueryBuilderConfig module-name="QueryBuilder" parser-class=
   "com.sun.mdm.index.configurator.impl.querybuilder.QueryBuilderConfiguration">
   <query-builder name="ALPHA-SEARCH"
    class="com.sun.mdm.index.querybuilder.BasicQueryBuilder"
    parser-class="com.sun.mdm.index.configurator.impl.querybuilder.
    KeyValueConfiguration" standardize="true" phoneticize="false">
      <config>
         <option key="UseWildcard" value="true"/>
      </config>
   </query-builder>
   <query-builder name="PHONETIC-SEARCH"
    KeyValueConfiguration" standardize="true" phoneticize="true">
      <config>
         <option key="UseWildcard" value="false"/>
      </config>
   </query-builder>
   <query-builder name="BLOCKER-SEARCH"
    class="com.sun.mdm.index.querybuilder.BlockerQueryBuilder" parser-
    class="com.sun.mdm.index.configurator.impl.blocker.BlockerConfig"
      <config>
         <block-definition number="ID000000">
            <block-rule>
               <equals>
                  <field>Enterprise.SystemSBR.Person.FnamePhonetic
                  </field>
                  <source>Person.FnamePhoneticCode</source>
               </equals>
               <equals>
                  <field>Enterprise.SystemSBR.Person.LnamePhonetic
                  </field>
                  <source>Person.LnamePhoneticCode</source>
               </equals>
            </block-rule>
         </block-definition>
         <block-definition number="ID000001">
            <block-rule>
               <equals>
                  <field>Enterprise.SystemSBR.Person.SSN</field>
                  <source>Person.SSN</source>
               </equals>
            </block-rule>
         </block-definition>
         <block-definition number="ID000002">
            <hint>ALL_ROWS</hint>
            <block-rule>
               <equals>
                  </field>
               </equals>
               <range>
                  <field>Enterprise.SystemSBR.Person.DOB</field>
                  <source>Person.DOB</source>
                  <default>
                     <lower-bound type="offset">-5</lower-bound>
                     <upper-bound type="offset">5</upper-bound>
                  </default>
               </range>
               <equals>
                  <field>Enterprise.SystemSBR.Person.Gender</field>
                  <source>Person.Gender</source>
               </equals>
            </block-rule>
         </block-definition>
      </config>
   </query-builder>
</QueryBuilderConfig>
Both basic and blocking queries can be configured to perform both exact searches and range searches. The following topics describe how different configurations of exact and range searches are processed.
Basic Query Range Searching
Range searching for basic queries is configured in the search page section of midm.xml by tagging the field with a “choice” attribute. When you specify a field for range searching, two corresponding fields appear on the MIDM with “From” and “To” appended to the name (for example, a field named “Date of Birth” would display two fields: “Date of Birth From” and Date of Birth To”). You can also define a field for both exact and range searching by defining the field twice for the search page, once with the choice attribute set to “exact” and once with it set to “range”. In this case, three fields appear on the MIDM: one with the given field name, one with “From” appended to the name, and one with “To” appended to the name.
Table 3 describes the queries formed for different exact or range search scenarios. Table 4 describes the queries formed for combination exact and range search scenarios.
The following variables are used in these tables:
Table 3 Standard Range Queries
Field Configuration in midm.xml
Resulting Fields on MIDM
Fields Populated for Search
Where Clause
field_name
field_name
where field_name = value
choice attribute set to “range”
field_name From
field_name To
field_name From
field_name To
where field_name >= value_from and field_name <= value_to
field_name From
field_name To
field_name From
field_name From
field_name To
field_name To
where field_name <= value_to
In the following table, when field_name is populated but not used in the WHERE clause, its value is used for weighting purposes. These cases are marked with an asterisk (*).
Table 4 Combination Exact and Range Queries
Where Clause
field defined once with choice attribute set to “exact” and once with it set to “range”
field_name
field_name From
field_name To
field_name
field_name
field_name From
field_name To
field_name From
field_name To
field_name
field_name From
field_name To
field_name From
field_name
field_name From
field_name To
field_name To
field defined once with choice attribute set to “exact” and once with it set to “range” *
field_name
field_name From
field_name To
field_name
field_name From
field_name
field_name From
field_name To
field_name
field_name To
field_name
field_name From
field_name To
field_name
field_name From
field_name To
Blocking Query Range Searching
Blocking queries are configured in query.xml, and, if the blocking query is used on the MIDM, in midm.xml. In order for the fields defined for range searching in the blocking query to appear on the MIDM, the fields must be configured correctly in midm.xml.
In addition to the standard range searching (described under Basic Query Range Searching), blocking queries support constant and offset range searches, allowing you to specify default upper and lower offset values or to specify upper and lower constant limits. Using offsets adds the specified values to the actual field value to determine the range on which to search. Note that this means the lower offset value should be a negative number and the upper offset value should be a positive number in order to create a valid range. You can also define a combination of a constant upper limit with lower offset value or a constant lower limit with an upper offset value.
Blocking Query Offset Values
When upper and lower offset values are defined, the application searches for values that are greater than or equal to the field value plus the lower offset value (which is typically a negative number) and less than or equal to the field value plus the upper offset value. You do not need to define both an upper and a lower offset value.
Note –
For date fields, the method for adding the offsets is different for numeric than for date type fields. For numeric data types, the offset value is added to the actual number. For date data types, the offset value is added to the day portion of the date (for example, if the offsets were -5 and +5 and the date entered is 01/10/2005, then the upper and lower bounds would be 01/05/2005 and 01/15/2005).
Table 5 describes the queries formed for different exact or range offset search scenarios. Table 6 describes the query formed for combination exact and offset range search scenarios.
Table 5 Standard Offset Range Queries
Offset Configuration in query.xml
Where Clause
field_name
both upper and lower offsets defined
field_name
where field_name >= (value + lower) and field_name <= (value + upper)
field_name
only lower offset defined
field_name
field_name
only upper offset defined
field_name
where field_name <= (value + upper)
field_name From
field_name To
upper, lower, or both offsets are defined
field_name From
field_name To
field_name From
field_name To
field_name From
field_name From
field_name To
field_name To
In Table 6, the field configuration in midm.xml defines the field twice for searching, once with the choice attribute set to “exact” and once with it set to “range”.
In the following cases, when field_name is populated but not used in the WHERE clause, its value is used for weighting purposes. These cases are marked with an asterisk (*).
Table 6 Combination Offset Range Queries
Fields on MIDM
Query Result
both upper and lower bound offsets are defined
field_name
field_name From
field_name To
field_name
only a lower offset is defined
field_name
field_name From
field_name To
field_name
only an upper offset is defined
field_name
field_name From
field_name To
field_name
field_name
field_name From
field_name To
field_name From
field_name To
field_name
field_name From
field_name To
field_name From
field_name
field_name From
field_name To
field_name To
both upper and lower offsets are defined
field_name
field_name From
field_name To
field_name
field_name From
where field_name >= value_from and field_name <= (value + upper)
field_name
field_name From
field_name To
field_name
field_name From
field_name
field_name From
field_name To
field_name
field_name From
field_name
field_name From
field_name To
field_name
field_name To
where field_name <= value_to and field_name >= (value + lower)
field_name
field_name From
field_name To
field_name
field_name To
field_name
field_name From
field_name To
field_name
field_name To
both upper and lower offsets are defined*
field_name
field_name From
field_name To
field_name
field_name From
field_name To
Blocking Query Constants
When you define upper and lower constants for a field, these values are used for the WHERE clause of the query if no data is passed in as search criteria for that field. They are also used when only one of the “from” or “to” fields is populated. You do not need to define both an upper and a lower constant value. If you define only an upper constant value, only a “less than or equals” clause is used in the query; if you define only a lower constant value, only a “greater than or equals” clause is used in the query.
Note –
For numeric type fields, the constant must be defined as all digits, with one decimal point allowed. For date type fields, the constant must be in the standard SQL format of yyyy-mm-dd.
Table 7 describes the queries formed for different exact or range constant search scenarios. Table 8 describes the query formed for combination exact and range search scenarios.
Table 7 Standard Constant Range Queries
Where Clause
field_name
field_name
field_name From
field_name To
field_name From
field_name To
field_name From
field_name To
field_name From
where field_name >= value_from and field_name <= upper
field_name From
field_name To
field_name To
where field_name <= value_to and field_name >= lower
In Table 8, the field configuration in midm.xml defines the field twice for searching, once with the choice attribute set to “exact” and once with it set to “range”.
Table 8 Combination Constant Range Queries
Fields on MIDM
Query Result
upper, lower, or both constants are defined
field_name
field_name From
field_name To
field_name
field_name
field_name From
field_name To
field_name From
field_name To
either upper or both constants are defined
field_name
field_name From
field_name To
field_name From
lower constant is defined
field_name
field_name From
field_name To
field_name From
field_name
field_name From
field_name To
field_name
field_name From
lower constant is defined *
field_name
field_name From
field_name To
field_name
field_name From
either lower or both constants are defined
field_name
field_name From
field_name To
field_name To
upper constant is defined
field_name
field_name From
field_name To
field_name To
field_name
field_name From
field_name To
field_name
field_name To
upper constant is defined *
field_name
field_name From
field_name To
field_name
field_name To
upper, lower, or both constants are defined *
field_name
field_name From
field_name To
field_name
field_name From
field_name To
Blocking Query Offset and Constant Combinations
You can use a combination of offset and constant values to define range searching for a field. Table 9 describes the query formed for combination offset and constant search scenarios.
In Table 9, the field configuration in midm.xml defines the field twice for searching, once with the choice attribute set to “exact” and once with it set to “range”.
Table 9 Combination Constant and Offset Range Queries
Fields on MIDM
Query Result
upper offset and lower constant are defined
field_name
field_name From
field_name To
field_name
where field_name >= lower and field_name <= (value + upper)
field_name
field_name From
field_name To
field_name From
field_name To
field_name
field_name From
field_name To
field_name From
field_name
field_name From
field_name To
field_name To
field_name
field_name From
field_name To
field_name
field_name From
where field_name <= (value + upper) and field_name >= value_from
field_name
field_name From
field_name To
field_name
field_name To
upper offset and lower constant are defined *
field_name
field_name From
field_name To
field_name
field_name From
field_name To
upper constant and lower offset are defined
field_name
field_name From
field_name To
field_name
where field_name <= upper and field_name >= (value + lower)
field_name
field_name From
field_name To
field_name From
field_name To
field_name
field_name From
field_name To
field_name From
field_name
field_name From
field_name To
field_name To
upper constant and lower offset are defined *
field_name
field_name From
field_name To
field_name
field_name From
where field_name <= upper and field_name >= value_from
field_name
field_name From
field_name To
field_name
field_name To
upper constant and lower offset are defined +
field_name
field_name From
field_name To
field_name
field_name From
field_name To
