| Skip Navigation Links | |
| Exit Print View | |
Sun Storage 6 Gb SAS PCIe RAID HBA, Internal Installation Guide For HBA Models SGX-SAS6-R-INT-Z and SG-SAS6-R-INT-Z |
Valid Drive Mix Configurations With HDDs and SSDs
Operating System and Technology Requirements
Chapter 2 Hardware Installation and Removal
Chapter 3 Creating a Bootable Drive in a Preboot Environment
The following are the SAS/SATA features supported by the HBA:
Serial SCSI protocol (SSP) and serial ATA tunneling protocol (STP), as defined in the Serial Attached SCSI (SAS) Specification, version 2.0
ANSI, as defined in the Serial Attached SCSI Standard, version 2.0
Serial ATA II protocol, as defined in the Serial ATA Specification, version 1.0a and the Serial ATAII; Extension to the Serial ATA Specification, version 1.1
Transfer of data using SCSI information units
Scalable interface that supports up to 248 devices through the use of expanders
Wide port support: consisting of 2, 3, or 4 PHYs within a single quad port
Narrow ports, consisting of a single PHY
Eight fully independent PHYs
6 Gb/s Serial Attached SCSI data transfers per PHY
3 Gb/s SATA II data transfers per PHY
Support for these SATA II features:
Configurable drive spin-up sequencing on a per-PHY basis
Hot plugging
Native command queuing
Activity and fault indicators for each PHY
Port selector (for dual-port drives)
