| Skip Navigation Links | |
| Exit Print View | |
Sun Storage 6 Gb SAS PCIe RAID HBA, Internal Installation Guide For HBA Models SGX-SAS6-R-INT-Z and SG-SAS6-R-INT-Z |
Operating System and Technology Requirements
Chapter 2 Hardware Installation and Removal
Chapter 3 Creating a Bootable Drive in a Preboot Environment
This HBA supports connectivity using labeled SATA II drives, SAS drives, or both. The following are some basic rules about the types of drives you can use:
Within a logical volume:
You can mix SAS and SATA drives (either all solid state drives (SSDs) or all hard disk drives (HDDs)).
You cannot mix HDDs and SSDs of any type.
Within an enclosure (SAS expander or direct-connect SAS cable), you can mix any drive types, subject to any restrictions imposed by the enclosure.
