| Skip Navigation Links | |
| Exit Print View | |
Sun Storage 6 Gb SAS PCIe RAID HBA, Internal Installation Guide For HBA Models SGX-SAS6-R-INT-Z and SG-SAS6-R-INT-Z |
Chapter 2 Hardware Installation and Removal
Chapter 3 Creating a Bootable Drive in a Preboot Environment
Chapter 4 HBA Software Installation
MegaRAID Storage Manager-Related Issues
Debug Messages Are Displayed in the Terminal Window
Error Messages Are Displayed When Attempting to Connect to Another Host
Cannot Enter the Login Password for the GUI and CLI
Administrative Actions Are Inaccessible Through the MSM GUI
Cannot Create a Drive Group Through the MSM GUI
sas_snmp and sas_ir_snmp Errors Occur During the MSM GUI Installation
Connection Refusal Error Messages Occur When Trying to Start the MSM GUI
Monitoring System Is Displayed as a MegaRAID Server in the MSM GUI
MSM GUI Is Not Starting After Becoming the root User
Cannot Locate a Disk Because the Blue Ready-to-Remove LED Is Not Illuminated
Cannot Save Controller Events From the UEFI HII Menu
Cannot Clear Controller Events From the UEFI HII Menu
The Advanced Software Options Feature on the WebBIOS Utility Menu Is Not Supported
Mouse Actions Are Erratic When Using the WebBIOS Utility
MegaCLI Log Files Are in the /tmp Directory
Unsupported RAID Levels Are Displayed in the MegaCLI Utility
Error Message Occurs After Issuing the MegaCli64 -AdpAlILog -aALL Command
Mouse Clicks Are Not Detected by the WebBIOS Utility
Cannot Tell, Through the WebBIOS Utility, When the Copyback Process Is Completed
Cannot Boot the Operating System
Blue Ready-to-Remove LED Is Illuminated After Reinserting a Drive
Bug 15568174
Issue: You will encounter these Java error messages if you are a non-root user attempting to start the MegaRAID Storage Manager (MSM) graphical user interface (GUI).
Workaround: Because only the root user can start the MSM GUI, do the following:
