This chapter describes the components that are provided with the Solaris implementation of Mobile IP. To use Mobile IP, you must first configure the Mobile IP configuration file by using the parameters and commands that are described in this chapter.
This chapter contains the following information:
The Mobile IP feature is removed from Solaris 10 updates after Solaris 10 8/07.
The mobility agent software incorporates home agent and foreign agent functionality. The Solaris Mobile IP software does not provide a client mobile node. Only the agent functionality is provided. Each network with mobility support should have at least one static (non-mobile) host running this software.
The following RFC functions are supported in the Solaris implementation of Mobile IP:
The base Mobile IP protocol (RFC 2002) does not address the problem of scalable key distribution and treats key distribution as an orthogonal issue. The Solaris Mobile IP software utilizes only manually configured keys, specified in a configuration file.
The following RFC functions are not supported in the Solaris implementation of Mobile IP:
The following functions are not supported in the Solaris implementation of Mobile IP:
The forwarding of multicast traffic or broadcast traffic by the home agent to the foreign agent for a mobile node that is visiting a foreign network
The routing of broadcast and multicast datagrams through reverse tunnels
Private care-of addresses or private home agent addresses
See the mipagent(1M) man page for additional information.
The mipagent command reads configuration information from the /etc/inet/mipagent.conf configuration file at startup. Mobile IP uses the /etc/inet/mipagent.conf configuration file to initialize the Mobile IP mobility agent. When configured and deployed, the mobility agent issues periodic router advertisements and responds to router discovery solicitation messages as well as Mobile IP registration messages.
See the mipagent.conf(4) man page for a description of file attributes. See the mipagent(1M) man page for a description of this file's usage.
The Mobile IP configuration file consists of sections. Each section has a unique name and is enclosed in square brackets. Each section contains one or more labels. You assign values to the labels by using the following format:
[Section_name]
Label-name = value-assigned
Configuration File Sections and Labels describes the section names, labels, and possible values.
The default Solaris installation provides the following sample configuration files in the /etc/inet directory:
mipagent.conf-sample – Contains a sample configuration for a Mobile IP agent that provides both foreign agent and home agent functionality
mipagent.conf.fa-sample – Contains a sample configuration for a Mobile IP agent that provides only foreign agent functionality
mipagent.conf.ha-sample – Contains a sample configuration for a Mobile IP agent that provides only home agent functionality
These sample configuration files contain mobile node address and security settings. Before you can implement Mobile IP, you must create a configuration file with the name mipagent.conf and place it in the /etc/inet directory. This file contains the configuration settings that satisfy your Mobile IP implementation requirements. You can also choose one of the sample configuration files, modify it with your addresses and security settings, and copy it to /etc/inet/mipagent.conf.
For more information, see How to Create the Mobile IP Configuration File.
The following listing shows the sections, labels, and values that are contained in the mipagent.conf-sample file. Configuration File Sections and Labels describes the syntax, sections, labels, and values.
[General] Version = 1.0 # version number for the configuration file. (required) [Advertisements hme0] HomeAgent = yes ForeignAgent = yes PrefixFlags = yes AdvertiseOnBcast = yes RegLifetime = 200 AdvLifetime = 200 AdvFrequency = 5 ReverseTunnel = no ReverseTunnelRequired = no [GlobalSecurityParameters] MaxClockSkew = 300 HA-FAauth = yes MN-FAauth = yes Challenge = no KeyDistribution = files [Pool 1] BaseAddress = 10.68.30.7 Size = 4 [SPI 257] ReplayMethod = none Key = 11111111111111111111111111111111 [SPI 258] ReplayMethod = none Key = 15111111111111111111111111111111 [Address 10.1.1.1] Type = node SPI = 258 [Address mobilenode@sun.com] Type = node SPI = 257 Pool = 1 [Address Node-Default] Type = node SPI = 258 Pool = 1 [Address 10.68.30.36] Type = agent SPI = 257 |
The following listing shows the sections, labels, and values that are contained in the mipagent.conf.fa-sample file. Configuration File Sections and Labels describes the syntax, sections, labels, and values.
The mipagent.conf.fa-sample file shows a configuration that provides only foreign agent functionality. This sample file does not contain a Pool section because pools are used only by a home agent. Otherwise, this file is the same as the mipagent.conf-sample file.
[General] Version = 1.0 # version number for the configuration file. (required) [Advertisements hme0] HomeAgent = no ForeignAgent = yes PrefixFlags = yes AdvertiseOnBcast = yes RegLifetime = 200 AdvLifetime = 200 AdvFrequency = 5 ReverseTunnel = yes ReverseTunnelRequired = no [GlobalSecurityParameters] MaxClockSkew = 300 HA-FAauth = yes MN-FAauth = yes Challenge = no KeyDistribution = files [SPI 257] ReplayMethod = none Key = 11111111111111111111111111111111 [SPI 258] ReplayMethod = none Key = 15111111111111111111111111111111 [Address 10.1.1.1] Type = node SPI = 258 [Address 10.68.30.36] Type = agent SPI = 257 |
The following listing shows the sections, labels, and values that are contained in the mipagent.conf.ha-sample file. Configuration File Sections and Labels describes the syntax, sections, labels, and values.
The mipagent.conf.ha-sample file shows a configuration that provides only home agent functionality. Otherwise, this file is the same as the mipagent.conf-sample file.
[General] Version = 1.0 # version number for the configuration file. (required) [Advertisements hme0] HomeAgent = yes ForeignAgent = no PrefixFlags = yes AdvertiseOnBcast = yes RegLifetime = 200 AdvLifetime = 200 AdvFrequency = 5 ReverseTunnel = yes ReverseTunnelRequired = no [GlobalSecurityParameters] MaxClockSkew = 300 HA-FAauth = yes MN-FAauth = yes Challenge = no KeyDistribution = files [Pool 1] BaseAddress = 10.68.30.7 Size = 4 [SPI 257] ReplayMethod = none Key = 11111111111111111111111111111111 [SPI 258] ReplayMethod = none Key = 15111111111111111111111111111111 [Address 10.1.1.1] Type = node SPI = 258 [Address mobilenode@sun.com] Type = node SPI = 257 Pool = 1 [Address Node-Default] Type = node SPI = 258 Pool = 1 |
The Mobile IP configuration file contains the following sections:
General (Required)
Advertisements (Required)
GlobalSecurityParameters (Optional)
Pool (Optional)
SPI (Optional)
Address (Optional)
The General and GlobalSecurityParameters sections contain information relevant to the operation of the Mobile IP agent. These sections can appear only once in the configuration file.
The General section contains only one label: the version number of the configuration file. The General section has the following syntax:
[General]
Version = 1.0
The Advertisements section contains the HomeAgent and ForeignAgent labels, as well as other labels. You must include a different Advertisements section for each interface on the local host that provides Mobile IP services. The Advertisements section has the following syntax:
[Advertisements interface]
HomeAgent = <yes/no>
ForeignAgent = <yes/no>
Typically, your system has a single interface, such as eri0 or hme0, and supports both home agent and foreign agent operations. If this situation exists for the example hme0, then the yes value is assigned to both the HomeAgent and ForeignAgent labels as follows:
HomeAgent = yes
ForeignAgent = yes
For advertisement over dynamic interfaces, use '*' for the device ID part. For example, Interface-name ppp* actually implies all PPP interfaces that are configured after the mipagent daemon has been started. All the attributes in the advertisement section of a dynamic interface type remain the same.
The following table describes the labels and values that you can use in the Advertisements section.
Table 29–1 Advertisements Section Labels and Values
The GlobalSecurityParameters section contains the labels maxClockSkew, HA-FAauth, MN-FAauth, Challenge, and KeyDistribution. This section has the following syntax:
MaxClockSkew = n
HA-FAauth = <yes/no>
MN-FAauth = <yes/no>
Challenge = <yes/no>
The Mobile IP protocol provides message replay protection by allowing timestamps to be present in the messages. If the clocks differ, the home agent returns an error to the mobile node with the current time and the mobile node can register again by using the current time. You use the MaxClockSkew label to configure the maximum number of seconds that differ between the home agent and the mobile node's clocks. The default value is 300 seconds.
The HA-FAauth and MN-FAauth labels enable or disable the requirement for home-foreign and mobile-foreign authentication, respectively. The default value is disabled. You use the challenge label so that the foreign agent issues challenges to the mobile node in its advertisements. The label is used for replay protection. The default value is disabled here, also.
The following table describes the labels and values that you can use in the GlobalSecurityParameters section.
Table 29–2 GlobalSecurityParameters Section Labels and Values
Mobile nodes can be assigned dynamic addresses by the home agent. Dynamic address assignment is done within the mipagent daemon independently of DHCP. You can create an address pool that can be used by mobile nodes by requesting a home address. Address pools are configured through the Pool section in the configuration file.
The Pool section contains the BaseAddress and Size labels. The Pool section has the following syntax:
[Pool pool-identifier]
BaseAddress = IP-address
Size = size
If you use a Pool identifier, then it must also exist in the mobile node's Address section.
You use the Pool section to define address pools that can be assigned to the mobile nodes. You use the BaseAddress label to set the first IP address in the pool. You use the Size label to specify the number of addresses available in the pool.
For example, if IP addresses 192.168.1.1 through 192.168.1.100 are reserved in pool 10, the Pool section has the following entry:
[Pool 10]
BaseAddress = 192.168.1.1
Size = 100
Address ranges should not encompass the broadcast address. For example, you should not assign BaseAddress = 192.168.1.200 and Size = 60, because this range encompasses the broadcast address 192.168.1.255.
The following table describes the labels and values that are used in the Pool section.
Table 29–3 Pool Section Labels and Values|
Label |
Value |
Description |
BaseAddress |
n.n.n.n | |
Size |
n |
Because the Mobile IP protocol requires message authentication, you must identify the security context by using a security parameter index (SPI). You define the security context in the SPI section. You must include a different SPI section for each security context that is defined. A numerical ID identifies the security context. The Mobile IP protocol reserves the first 256 SPIs. Therefore, you should use only SPI values greater than 256. The SPI section contains security-related information, such as shared secrets and replay protection.
The SPI section also contains the ReplayMethod and Key labels. The SPI section has the following syntax:
[SPI SPI-identifier]
ReplayMethod = <none/timestamps>
Key = key
Two communicating peers must share the same SPI identifier. You must configure them with the same key and replay method. You specify the key as a string of hexadecimal digits. The maximum length is 16 bytes. For example, if the key is 16 bytes long, and contains the hexadecimal values 0 through f, the key string might resemble the following:
Key = 0102030405060708090a0b0c0d0e0f10 |
Keys must have an even number of digits, corresponding to the two digits per byte representation.
The following table describes the labels and values that you can use in the SPI section.
Table 29–4 SPI Section Labels and Values|
Label |
Value |
Description |
ReplayMethod |
none or timestamps |
Specifies the type of replay authentication used for the SPI |
Key |
x |
The Solaris implementation of Mobile IP enables you to configure mobile nodes using one of three methods. Each method is configured in the Address section. The first method follows the traditional Mobile IP protocol, and requires that each mobile node have a home address. The second method enables a mobile node to be identified through its Network Access Identifier (NAI). The last method enables you to configure a default mobile node, which can be used by any mobile node that has the proper SPI value and related keying material.
The Address section for a mobile node contains the Type and SPI labels that define the address type and SPI identifier. The Address section has the following syntax:
[Address address]
Type = node
SPI = SPI-identifier
You must include an Address section in a home agent's configuration file for each mobile node that is supported.
If Mobile IP message authentication is required between the foreign agent and home agent, you must include an Address section for each peer with which an agent needs to communicate.
The SPI value that you configure must represent an SPI section that is present in the configuration file.
You can also configure private addresses for a mobile node.
The following table describes the labels and values that you can use in the Address section for a mobile node.
Table 29–5 Address Section Labels and Values (Mobile Node)|
Label |
Value |
Description |
Type |
node | |
SPI |
n |
The Address section for a mobility agent contains the Type and SPI labels that define the address type and SPI identifier. The Address section for a mobility agent has the following syntax:
[Address address]
Type = agent
You must include an Address section in a home agent's configuration file for each mobility agent that is supported.
If Mobile IP message authentication is required between the foreign agent and the home agent, you must include an Address section for each peer with which an agent needs to communicate.
The following table describes the labels and values that you can use in the Address section for a mobility agent.
Table 29–6 Address Section Labels and Values (Mobility Agent)|
Label |
Value |
Description |
Type |
agent |
Specifies that the entry is for a mobility agent |
SPI |
n |
Specifies the SPI value for the associated entry |
The Address section for a mobile node that is identified by its NAI contains the Type, SPI, and Pool labels. The NAI parameter enables you to identify mobile nodes through their NAI. The Address section, using the NAI parameter, has the following syntax:
[Address NAI]
Type = Node
Pool = pool-identifier
To use pools, you identify mobile nodes through their NAI. The Address section permits you to configure an NAI, as opposed to a home address. An NAI uses the format user@domain. You use the Pool label to specify which address pool to use in order to allocate the home address to the mobile node.
The following table describes the labels and values that you can use in the Address section for a mobile node that is identified by its NAI.
Table 29–7 Address Section Labels and Values (Mobile Node Identified by Its NAI)|
Label |
Value |
Description |
Type |
node | |
SPI |
n | |
Pool |
n |
Allocates the pool from which an address is assigned to a mobile node |
You must have corresponding SPI and Pool sections for the SPI and Pool labels that are defined in an Address section with a mobile node that is identified by its NAI, as shown in the following figure.
The Address section for a default mobile node contains the Type, SPI, and Pool labels. The Node-Default parameter enables you to permit all mobile nodes to get service if they have the correct SPI (defined in this section). The Address section, using the Node-Default parameter, has the following syntax:
Type = Node
The Node-Default parameter enables you to reduce the size of the configuration file. Otherwise, each mobile node requires its own section. However, the Node-Default parameter does pose a security risk. If a mobile node is no longer trusted for any reason, you need to update the security information on all trusted mobile nodes. This task can be very tedious. However, you can use the Node-Default parameter in networks that consider security risks unimportant.
The following table describes the labels and values that you can use in the Address section for a default mobile node.
Table 29–8 Address Section Labels and Values (Default Mobile Node)|
Label |
Value |
Description |
Type |
node | |
SPI |
n | |
Pool |
n |
You must have corresponding SPI and Pool sections for the SPI and Pool labels that are defined in the Address section with a default mobile node, as shown in the following figure.
You can use the mipagentconfig command to configure the mobility agent. This command enables you to create or modify any parameter in the /etc/inet/mipagent.conf configuration file. Specifically, you can change any setting. Also, you can add or delete mobility clients, pools, and SPIs. The mipagentconfig command has the following syntax:
# mipagentconfig <command> <parameter> <value> |
The following table describes the commands that you can use with mipagentconfig to create or modify parameters in the /etc/inet/mipagent.conf configuration file.
Table 29–9 mipagentconfig Subcommands|
Command |
Description |
add |
Used to add advertisement parameters, security parameters, SPIs, and addresses to the configuration file |
change |
Used to change advertisement parameters, security parameters, SPIs, and addresses in the configuration file |
delete |
Used to delete advertisement parameters, security parameters, SPIs, and addresses from the configuration file |
get |
Used to display current values in the configuration file |
See the mipagentconfig(1M) man page for a description of command parameters and acceptable values. Modifying the Mobile IP Configuration File provides procedures that use the mipagentconfig command.
You can use the mipagentstat command to display a foreign agent's visitor list and a home agent's binding table. You can also display the security associations with an agent's mobility agent peers. To display the foreign agent visitor list, you use the mipagentstat command's -f option. To display the home agent binding table, you use the mipagentstat command's -h option. The following examples show typical output when the mipagentstat command is used with these options.
Mobile Node Home Agent Time (s) Time (s) Flags
Granted Remaining
foobar.xyz.com ha1.xyz.com 600 125 .....T.
10.1.5.23 10.1.5.1 1000 10 .....T.
Granted Remaining
foobar.xyz.com fa1.tuv.com 600 125 .....T.
10.1.5.23 123.2.5.12 1000 10 .....T.
See the mipagentstat(1M) man page for more information about the command's options. Displaying Mobility Agent Status provides procedures that use the mipagentstat command.
On shutdown, the mipagent daemon stores internal state information in /var/inet/mipagent_state. This event occurs only when the mipagent provides services as a home agent. This state information includes the list of mobile nodes that are being supported as a home agent, their current care-of addresses, and remaining registration lifetimes. This state information also includes the security association configuration with mobility agent peers. If the mipagent daemon is terminated for maintenance and restarted, mipagent_state is used to recreate as much of the mobility agent's internal state as possible. The intention is to minimize service disruption for mobile nodes that might be visiting other networks. If mipagent_state exists, it is read immediately after mipagent.conf every time mipagent is started or restarted.
Mobile IP extensions have been added to the netstat command to identify Mobile IP forwarding routes. Specifically, you can use the netstat command to display a new routing table that is called “Source-Specific.” See the netstat(1M) man page for more information.
The following example shows the output of netstat when you use the -nr flags.
Routing Table: IPv4 Source-Specific
Destination In If Source Gateway Flags Use Out If
10.6.32.11 ip.tun1 -- 10.6.32.97 UH 0 hme1
-- hme1 10.6.32.11 -- U 0 ip.tun1
The example shows the routes for a foreign agent that uses a reverse tunnel. The first line indicates that the destination IP address 10.6.32.11 and the incoming interface ip.tun1 select hme1 as the interface that forwards the packets. The next line indicates that any packet that originates from interface hme1 and source address 10.6.32.11 must be forwarded to ip.tun1.
Mobile IP extensions have been added to the snoop command to identify Mobile IP traffic on the link. See the snoop(1M) man page for more information.
The following example shows the output of snoop that runs on the mobile node, mip-mn2.
mip-mn2# snoop
Using device /dev/hme (promiscuous mode)
mip-fa2 -> 224.0.0.1 ICMP Router advertisement (Lifetime 200s [1]:
{mip-fa2-80 2147483648}), (Mobility Agent Extension), (Prefix Lengths),
(Padding)
mip-mn2 -> mip-fa2 Mobile IP reg rqst
mip-fa2 -> mip-mn2 Mobile IP reg reply (OK code 0)
This example shows that the mobile node received one of the periodically sent mobility agent advertisements from the foreign agent, mip-fa2. Then, mip-mn2 sent a registration request to mip-fa2, and in response, received a registration reply. The registration reply indicates that the mobile node successfully registered with its home agent.
