Configuring the RIP Topology Example
Configuring the RIP Packet Retransmission Interval and Retry Count
Set the RIP Packet Retransmission Interval and Retry Count
Reset the Retransmission Interval and Retry Count
Configuring the RIP Passive Interface
Enable the RIP Passive Interface
Disable the RIP Passive Interface
Configuring the Default Metric
Managing the auto-summary Option
Disable the auto-summary Option
Enable the auto-summary Option
Configuring Interface-Specific RIP Parameters
Configuring Interface-Specific Authentication
Enable Interface-Specific Authentication
Enable Authentication on Both Switches
Disable Interface-Specific Authentication
Configuring the RIP Default Route Propagation
Set the Default Route Propagation
Test the Default Route Origination and Installation
Configuring the Version for Receiving RIP Advertisement
Configuring the Summary Address
Test the Summary Address Configuration
Configuring the split-horizon Option
Enable the split-horizon Option With Poison Reverse
Disable the split-horizon Option
SEFOS# configure terminal SEFOS(config)# interface vlan 1 SEFOS(config-if)# exit
SEFOS# configure terminal SEFOS(config)# router rip SEFOS(config-router)# network 10.0.0.1 SEFOS(config-router)# exit
SEFOS(config-if)# ip split-horizon
SEFOS# show ip protocols Routing Protocol is rip Vrf default RIP2 security level is Maximum Redistributing : rip, bgp, connected, ospf, static Output Delay is disabled Retransmission timeout interval is 5 seconds Number of retransmission retries is 36 Default metric is 3 Auto-Summarisation of routes is disabled Routing for Networks : 10.0.0.0 Routing Information Sources : Interface Specific Address Summarization : 40.0.0.0/8 for vlan1 Trusted Neighors : Interface vlan1 Sending updates every 60 seconds Invalid after 120 seconds Flushed after 120 seconds Send version is 1 2, receive version is 1 2 Authentication type is none Split Horizon is enabled Installs default route received Restricts default route origination
