Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
LLDP Administration Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
Protocol Description
Introduction
Configuring LLDP
Configuration Topology
Configuration Guidelines
Default Settings
Configure the LLDP System Control Status
Configure the LLDP Module Status
Configure LLDP Global Objects
Configure the LLDP Admin Status
Enable LLDP Optional TLVs
Enabling a Specific Management Address
Enable IEEE 802.1 Organizationally-Specific TLVs
Enabling a Particular VLAN Name
Enable a Particular PPVID
Enable IEEE 802.3 Organizationally-Specific TLVs
Disable LLDP Basic Optional TLVs
Disable IEEE 802.1 Organizationally-Specific TLVs
Disable the IEEE 802.3 Organizationally-Specific TLVs
Configure the LLDP Chassis-ID Subtype
Configure the LLDP Port-ID Subtype
Enable the LLDP Notification Status or Type
Clear the LLDP Traffic Counters
Clear the LLDP Remote Table
View LLDP Errors
Configure LLDP Trace Options
Introduction
Oracle's SEFOS LLDP enables devices attached to an IEEE 802 LAN to advertise their own information to other devices attached to the same IEEE 802 LAN and to learn about the other devices.The advertised information includes:
The advertised information is learned and stored by recipients in a standard MIB. Thus, a NMS can access the information using SNMP.
