Skip Navigation Links | |
Exit Print View | |
Sun Ethernet Fabric Operating System LLDP Administration Guide |
Configure the LLDP Module Status
Configure the LLDP Admin Status
Enabling a Specific Management Address
Enable an Existing IP Interface
Enable IEEE 802.1 Organizationally-Specific TLVs
Enabling a Particular VLAN Name
Enable IEEE 802.3 Organizationally-Specific TLVs
Disable LLDP Basic Optional TLVs
Disable IEEE 802.1 Organizationally-Specific TLVs
Disable the IEEE 802.3 Organizationally-Specific TLVs
Configure the LLDP Chassis-ID Subtype
Configure the LLDP Port-ID Subtype
Enable the LLDP Notification Status or Type
This section describes how to configure the LLDP system control status, which is set to Start by default. You must set the LLDP system control status to Start before you make any configuration changes in LLDP.
SEFOS# configure terminal SEFOS(config)# shutdown lldp SEFOS(config)# end
SEFOS# show lldp % Lldp Module is shutdown
SEFOS# configure terminal SEFOS(config)# no shutdown lldp SEFOS(config)# end
After the LLDP system control status is changed to Start, LLDP global configuration objects are set with default values.
SEFOS# show lldp LLDP is disabled Transmit Interval : 30 Holdtime Multiplier : 4 Reinitialization Delay : 2 Tx Delay : 2 Notification Interval : 5 Chassis Id SubType : Mac Address Chassis Id : 00:01:02:03:04:01
