Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
LLDP Administration Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
Protocol Description
Introduction
Configuring LLDP
Configuration Topology
Configuration Guidelines
Default Settings
Configure the LLDP System Control Status
Configure the LLDP Module Status
Configure LLDP Global Objects
Configure the LLDP Admin Status
Enable LLDP Optional TLVs
Enabling a Specific Management Address
Enable a New IP Address
Enable an Existing IP Interface
Enable IEEE 802.1 Organizationally-Specific TLVs
Enabling a Particular VLAN Name
Enable a New VLAN Name
Enable an Existing VLAN Name
Enable a Particular PPVID
Enable IEEE 802.3 Organizationally-Specific TLVs
Disable LLDP Basic Optional TLVs
Disable IEEE 802.1 Organizationally-Specific TLVs
Disable the IEEE 802.3 Organizationally-Specific TLVs
Configure the LLDP Chassis-ID Subtype
Configure the LLDP Port-ID Subtype
Enable the LLDP Notification Status or Type
Clear the LLDP Traffic Counters
Clear the LLDP Remote Table
View LLDP Errors
Configure LLDP Trace Options
The PPDVID TLV transmission status is disabled by default. If you configure a new PPVID, the TLV transmission status of the VLAN name is disabled by default. If you configure a new PPVID, the PPVID is not transmitted by default (the TLV transmission status of the newly configured PPVID is disabled).
  1. At switch 1, create and map protocols-group 10 to VLAN 2.
    SEFOS# configure terminal
    SEFOS(config)# map protocol ip enet-v2 protocols-group 10
    SEFOS(config)# interface extreme-ethernet 0/1
    SEFOS(config-if)# switchport map protocols-group 10 vlan 2
    SEFOS(config-if)# end
  2. Review the local system information.
    SEFOS# show lldp local extreme-ethernet 0/1
    Extended 802.1 TLV Info
    -Port VLAN Id                : 1
    -Port & Protocol VLAN Id
    Protocol VLAN Id   Support   Protocol VLAN Status   TxStatus
    2            Supported    Enabled        Disabled
  3. Enable the transmission of protocol VLAN ID TLVs.
    SEFOS(config-if)# lldp tlv-select dot1tlv port-vlan-id protocol-vlan-id 2
    SEFOS(config)# end
  4. Review the local system information.
    -Port VLAN Id                : 1
    2             Supported   Enabled           Enabled
  5. At switch 2, review the learned neighbor information on the interface extreme-ethernet 0/1.
    SEFOS# show lldp neighbors extreme-ethernet 0/1 detail
    -Port VLAN Id            : 1
    Protocol Vlan Id        Support            Status
    2                Supported            Enabled
  6. At switch 1, delete the PPVID (that is, unmap protocols-group 10 in the extreme-ethernet 0/1 interface).
    SEFOS(config-if)# no switchport map protocols-group 10
    SEFOS(config)# end
  7. Review the local system information.
    -Port VLAN Id                    : 1
    0            Supported   Enabled              Disabled
    No entry is displayed for the port-and-protocol VLAN ID.
  8. At switch 2, review the learned neighbor information on the extreme-ethernet 0/1 interface.
    -Port VLAN Id            : 1
    Protocol Vlan Tlv            : Not Advertised
  9. At switch 1, recreate the PPVID (that is, create and map protocols-group 10 to VLAN 2).
  10. Review the local system information.
    -Port VLAN Id                : 1
  11. At switch 2, review the learned neighbor information on the extreme-ethernet 0/1 interface.
    -Port VLAN Id                : 1
