Reducing Data Transmission Time Using the SPT
Specify the PIM Threshold That Triggers SPT Switching
Specify the PIM RP Threshold That Triggers Source-Specific Switching
Specify the PIM RP Switch Period
Monitor the Data Transfer Rate After a Register Stop Message
Enabling Static RP Configurations
Associate an Interface to a PIM Component
Configuring Designated Routers
Prioritize Router Messaging With PIM DR-Priority
Restore the Default Router Priority Designation
Configuring the PIM Override Interval
Specify the Interval to Delay Override Messages
Restore the Default Override Messaging Interval
Restore the Default LAN Delay Interval
Restore the Default BSR-Candidate Value
Configuring PIM Query Intervals
Specify the Hello Messaging Interval
Restore the Default Hello Messaging Interval
Configuring PIM Join and Prune Messaging
Specify the Join and Prune Messaging Interval
Restore the Default Message Interval
Configuring PIM Component Data Routing Modes
Configuring RP-Candidate Behavior
Specify the Address for the Candidate RP
Configuring RP Candidate Hold Time
Specify RP Candidate Hold Time
Restore the Default Candidate RP Hold Time
Specify the Address for the Static RP
You can specify the amount of time (in seconds) the data rate is monitored before data will be transmitted through the SPT. The SPT switching period must be configured to switch to SPT. You can instruct SPT switching to monitor the data rate for both the source and the group.
SEFOS# configure terminal SEFOS(config)# set ip pim enable SEFOS(config)# set ip pim threshold spt-grp 10 SEFOS(config)# set ip pim threshold spt-src 15 SEFOS(config)# set ip pim spt-switchperiod 5 SEFOS(config)# end
This example transmits data through the SPT when the data transfer rate for the group exceeds 10 bps. The switch monitors the activity for 5 seconds.
SEFOS# show ip pim thresholds PIM SPT Threshold Information ----------------------------- Group Threshold : 10 Source Threshold : 15 Switching Period : 5 PIM SPT-RP Threshold Information -------------------------------- Register Threshold : 0 RP Switching Period : 0 Register Stop rate limit : 5
