Reducing Data Transmission Time Using the SPT
Specify the PIM Threshold That Triggers SPT Switching
Specify the PIM SPT Switch Period
Specify the PIM RP Threshold That Triggers Source-Specific Switching
Monitor the Data Transfer Rate After a Register Stop Message
Enabling Static RP Configurations
Associate an Interface to a PIM Component
Configuring Designated Routers
Prioritize Router Messaging With PIM DR-Priority
Restore the Default Router Priority Designation
Configuring the PIM Override Interval
Specify the Interval to Delay Override Messages
Restore the Default Override Messaging Interval
Restore the Default LAN Delay Interval
Restore the Default BSR-Candidate Value
Configuring PIM Query Intervals
Specify the Hello Messaging Interval
Restore the Default Hello Messaging Interval
Configuring PIM Join and Prune Messaging
Specify the Join and Prune Messaging Interval
Restore the Default Message Interval
Configuring PIM Component Data Routing Modes
Configuring RP-Candidate Behavior
Specify the Address for the Candidate RP
Configuring RP Candidate Hold Time
Specify RP Candidate Hold Time
Restore the Default Candidate RP Hold Time
Specify the Address for the Static RP
You can specify the amount of time (in seconds) the RP monitors registered packets for switching to the source-specific SPT. The RP switching period must be configured to switch to SPT.
SEFOS# configure terminal SEFOS(config)# set ip pim enable SEFOS(config)# set ip pim rp-threshold 10 SEFOS(config)# set ip pim rp-switchperiod 15 SEFOS(config)# end
This example switches the RP to the source-specific SPT after 10 registered packets are received and monitors the activity for 15 seconds.
SEFOS# show ip pim thresholds PIM SPT Threshold Information ----------------------------- Group Threshold : 10 Source Threshold : 15 Switching Period : 5 PIM SPT-RP Threshold Information -------------------------------- Register Threshold : 10 RP Switching Period : 15 Register Stop rate limit : 5
