Reducing Data Transmission Time Using the SPT
Specify the PIM Threshold That Triggers SPT Switching
Specify the PIM SPT Switch Period
Specify the PIM RP Threshold That Triggers Source-Specific Switching
Specify the PIM RP Switch Period
Monitor the Data Transfer Rate After a Register Stop Message
Enabling Static RP Configurations
Associate an Interface to a PIM Component
Configuring Designated Routers
Prioritize Router Messaging With PIM DR-Priority
Restore the Default Router Priority Designation
Configuring the PIM Override Interval
Specify the Interval to Delay Override Messages
Restore the Default Override Messaging Interval
Restore the Default LAN Delay Interval
Restore the Default BSR-Candidate Value
Configuring PIM Query Intervals
Specify the Hello Messaging Interval
Restore the Default Hello Messaging Interval
Configuring PIM Join and Prune Messaging
Specify the Join and Prune Messaging Interval
Restore the Default Message Interval
Configuring PIM Component Data Routing Modes
Configuring RP-Candidate Behavior
Specify the Address for the Candidate RP
Configuring RP Candidate Hold Time
Specify RP Candidate Hold Time
Restore the Default Candidate RP Hold Time
This example advertises 10.1.0.2 as a static RP on PIM component 1, with a group address of 224.1.0.0 and a group mask of 255.255.0.0.
SEFOS# configure terminal SEFOS(config)# set ip pim enable
SEFOS(config)# set ip pim static-rp enable SEFOS(config)# interface vlan 5 SEFOS(config-if)# ip pim componentId 1
SEFOS(config-if)# ip pim query-interval 60 SEFOS(config-if)# exit SEFOS(config)#
SEFOS(config)# ip pim component 1
SEFOS(pim-comp)# rp-static rp-address 224.1.0.0 255.255.0.0 10.1.0.2 SEFOS(pim-comp)# end SEFOS#
SEFOS# show ip pim rp-static 1 Static-RP Enabled CompId GroupAddress Group Mask RPAddress ------ ------------ ---------- --------- 1 224.1.0.0 255.255.0.0 10.1.0.2
